Post by xthearrowx on Jun 3, 2015 15:55:31 GMT -5
For some reason it won't start and I don't know why. I just spend $281 to get it fixed from the place it was bought from and it worked perfectly for about 2 weeks and then it starts messing up again. A couple of days ago it was starting fine then the next day it wouldn't start unless I gave it gas and then if I let off the break, it would die immediatrly, now it will not start at all. Please help me It's my only transportation.
Post by xthearrowx on Jun 3, 2015 16:12:25 GMT -5
It was listed as a Roketa MC 31-50
Post by scooterpimp on Jun 3, 2015 18:00:10 GMT -5
What did the shop repair on your scoot? Is it doing the same thing that you took it to the shop for? Can you see if its getting fuel or spark? Just tossin some ideas out there. 4 stroke or 2?
Post by xthearrowx on Jun 3, 2015 18:17:13 GMT -5
Post by xthearrowx on Jun 3, 2015 18:18:23 GMT -5
That's a pic of the receipt!
Post by scooterpimp on Jun 3, 2015 18:24:25 GMT -5
Holy cow , whats with the question marks? , were you having a problem & they serviced it? $27.00 for a turnsignal flasher? & a signal switch? Hate to say it but it looks like a 4 year olds handwriting on the recipt , can you take it back , i mean almost $300 in repairs? They should stand behind thier work?
Post by xthearrowx on Jun 3, 2015 18:32:52 GMT -5
Is $27 bad for a turn signal? Yes they serviced all of that. I was having problems
Post by scooterpimp on Jun 3, 2015 18:39:24 GMT -5
Yup thats kinda high for a flasher. Then a switch too like they were guessing. Imo. Did they say the full service would fix your problem when you went there? Look for things like popped off vac hoses , unplugged plugs etc. Unless something they did failed when they did switch & flasher etc. Just tryin to help.
Post by xthearrowx on Jun 3, 2015 18:45:49 GMT -5
I have a video being posted to YouTube as we speak so you can see what's going on with the scooter they fixed my flasher which work now they fix the switch for the flasher because when I turn the flashers on the right side would stay on constantly even if I turn it on or off and the left side when I turned it on it would stay on as well as the right side and my electronics which was messed up as well so we had to fix that
Post by xthearrowx on Jun 3, 2015 18:46:41 GMT -5
Post by scooterpimp on Jun 3, 2015 19:02:43 GMT -5
Verify engine kill switch is on it looks to be off in video. (Red switch above start button) , try twisting throttle open& closed 2-3 times before hitting starter when first starting. (For giggles) kinda tuff to help without scoot in front of me., maybe visiting the tech section , you may see 90gtvert's pdi writeup & may get some insight there. Scoot needs 3 things to start. Air , fuel & spark..
Post by Fox on Jun 3, 2015 20:18:54 GMT -5
You been riding it in the rain?
Post by xthearrowx on Jun 3, 2015 20:48:12 GMT -5
I did once but it was sprinkling. It has been left in the rain before this, but I have seen people leave them outside in the rain and nothing happen. Why?
Post by xthearrowx on Jun 3, 2015 20:49:13 GMT -5
Verify engine kill switch is on it looks to be off in video. (Red switch above start button) , try twisting throttle open& closed 2-3 times before hitting starter when first starting. (For giggles) kinda tuff to help without scoot in front of me., maybe visiting the tech section , you may see 90gtvert's pdi writeup & may get some insight there. Scoot needs 3 things to start. Air , fuel & spark.. The switch is on or I wouldn't be able to turn it over.
Post by scooterpimp on Jun 3, 2015 20:55:33 GMT -5
It will still crank if kill switch is on the off position (r/s handle bar) , but wont allow engine to fire ,(most china scoots) should be slid over to circle looking thing. I cant count how many times i forgot to turn it to run in the past!
