Post by floyd2133 on Jul 11, 2016 2:16:57 GMT -5
Post by gsx600racer on Jul 11, 2016 6:19:50 GMT -5
Id check out the links below. Seem this guy is having the same problems. Looks like a lot of people here tried helping him out. Good Luck. link 1link 2 link 3link 4
Post by 90GTVert on Jul 11, 2016 7:23:10 GMT -5
It turns over, so check for fuel, spark, and compression. Wouldn't be a bad idea to make sure the battery is charged up well, just in case that's a little slower than it would like to turn over. More details : www.49ccscoot.com/faq/wontstart.html
Post by eclark5483 on Jul 11, 2016 12:03:11 GMT -5
I'm just wondering if maybe that piston or crank is damaged. It seemed to me in the video that the starter's turnover sound was slow. It COULD be the battery, but it could also be a seizing piston. Considering it's a BBK and was driven without a cooling shroud and hasn't had a proper break in, engine damage would be the first thing on my mind.
Post by floyd2133 on Jul 11, 2016 16:32:49 GMT -5
I just has a bbk100cc kit installed a month ago. everything on engine is new. so piston isn't a problem. what elselse should I try.?
Post by Deleted on Jul 11, 2016 17:22:51 GMT -5
I just has a bbk100cc kit installed a month ago. everything on engine is new. so piston isn't a problem. what elselse should I try.? But you not only ran it without the shrouds, you broke in the new piston and cylinder with no shrouds which means all of this happened under extreme heat. This is why he is asking about your piston, and other internal engine parts...it maybe/probably is not OK. It does not matter if the parts were new...running under extreme conditions can destroy ANY part no matter how new it might be.
Bill
PS You say in the title of this topic that it will not turn over but, your video clearly shows that it does. I don't get it???
Post by gsx600racer on Jul 11, 2016 18:37:16 GMT -5
You could try this,
Get it all put back together, take some pics. Put an ad on Craigslist and list all the go fast goodies and say it goes really fast(60+). Then say it doesn't currently run and probably needs the carb cleaned. Cut your losses. Then buy a new scooter(not from same place you had issues with)and leave it stock.
Post by floyd2133 on Jul 11, 2016 20:04:48 GMT -5
this is sadness
Post by floyd2133 on Jul 11, 2016 20:05:44 GMT -5
well should I sue I'm out 1000 dollars and owe 1500 on the scooter. I'm so bummed
Post by floyd2133 on Jul 11, 2016 20:07:08 GMT -5
I mean it will turn over but will not crank. any advice. is this bad?
Post by crawford on Jul 11, 2016 20:13:44 GMT -5
I don't get it you mess with motor and maybe screw it up and want to sue who? I think if you have the old parts put them on and try what else can you do. Maybe you get lucky or not.
Post by gsx600racer on Jul 12, 2016 0:29:39 GMT -5
Post by floyd2133 on Jul 12, 2016 1:14:26 GMT -5
I take it to the shop and every time it goes out Inn 2 3 days this has been happening since the end of may
Post by eclark5483 on Jul 12, 2016 4:26:31 GMT -5
Floyd, my best advice, is take it to a different mechanic. Tell them everything you told us, tell them what you have learned about the shroud and anything else you can think of. I'm almost certain without seeing it for myself, that you have engine damage from extreme heat and that's why it won't start and that is why it cranks over slow. The guy who did the BBK for you did not know what he was doing. It would be foolish to take something back to someone who screwed it up in the first place. Do like I said in a different post, get estimates from a different mechanic, take it to small claims court, ask for a judgement in the amount of what repairing it will cost. The more you keep trying to get the person who screwed it up to fix it, the bigger sucker you will make yourself out to be. Don't do that to yourself. Sure you could learn from most of us how to fix it yourself, but that is not the kind of justice you need. You need to have this whole incident made right, that goes far beyond what anybody here can do or advise you of. This site is really more for people who are enthusiasts with a basic understanding of engine dynamics. You my friend, need legal advice, not just technical advice. Nobody here can help you with that. I would suggest that you NOT try repairing anything yourself, get help locally. Not just to fix the scoot, but to recoup money that was swindled from you.
Post by floyd2133 on Jul 12, 2016 13:30:35 GMT -5
