Post by floyd2133 on Sept 6, 2016 10:39:04 GMT -5
Is it possible to remove drive belt with out impact wrench if so . Are there any videos?
Post by crawford on Sept 6, 2016 12:10:14 GMT -5
If you have a strap wrench to hold the cvt and a socket and ratchet and a hammer.
Post by aeroxbud on Sept 6, 2016 13:24:33 GMT -5
It depends on what engine you have some you can use a strap, some have a locking tool you can use. There at many different styles depending on engine.
Post by gsx600racer on Sept 6, 2016 17:36:05 GMT -5
Yup, here are several ways.
Post by Deleted on Sept 6, 2016 19:55:42 GMT -5
This is what I use...I have an impact and that works well to remove it but, I wanted something I could easily carry on the road with me. Also, I use this so I can use my torque wrench when putting that nut back on. These are about $10 on ebay if you look around. Bill
Post by dan50 on Sept 6, 2016 22:04:24 GMT -5
The variator locking tool that PirateLabs showed is well worth the money. I just got one and was easily able to take the variator off without my impact wrench.
Post by floyd2133 on Sept 8, 2016 5:54:19 GMT -5
Post by 90GTVert on Sept 8, 2016 7:57:15 GMT -5
The top tool in your pic isn't really a puller, just helps you hold some things. It would hold the clutch bell or flywheel. The bottom one is what you'd want to hold the variator on a 139QMB. You could use the top one to hold the flywheel while you remove the variator nut, but it's easier just to use the bottom tool.
Post by floyd2133 on Sept 8, 2016 9:44:59 GMT -5
I figured that u guys are great especially 90gtvert thanks
Post by floyd2133 on Sept 9, 2016 19:39:45 GMT -5
Ok so I bought a 729 belt jus until my 669 or 699 belt came n. It cranked up fine until I changed the carb to 2mm. So I installed the belt n changed it to the stock 18mm now it seems like it won't start. I have it on a trickle charge it started fine but it would not start with new carb. I changed it back same result. Any ideas it's only been a 4 days sitting . Video is in next post .
Post by gsx600racer on Sept 9, 2016 21:48:17 GMT -5
Check and make sure there are no vacuum leaks and your hoses are connected properly. Remember, you said it ran fine before carb swap, double check your work.
Post by floyd2133 on Sept 10, 2016 2:14:56 GMT -5
Here are pictures of carb I'm totally stumped please help
a66.tinypic.com/nzjfba.jpg a68.tinypic.com/eaim4g.jpg a66.tinypic.com/17elux.jpg a65.tinypic.com/2v26p2r.jpg a64.tinypic.com/2vv1fmr.jpg a64.tinypic.com/1zvwot5.jpg a66.tinypic.com/2h6uiwm.jpg
Post by floyd2133 on Sept 10, 2016 2:27:39 GMT -5
Post by floyd2133 on Sept 10, 2016 3:49:34 GMT -5
And yes I have already checked valves battery good new CDi new high performance cable. It was working before I changed carbs I made sure the intake manifold was snug I carb . Still not working . No push or kick. It. Turns over but won't crank ugh😡😡😡😡
Post by floyd2133 on Sept 10, 2016 3:50:01 GMT -5
Gas is getting to carb good
