Post by acvw74 on Sept 12, 2016 8:59:15 GMT -5
The battery that comes with the bikes aren't meant for daily use...just shipping. Voltage and amperage both have to be measured to indicate the health of a battery.
Typically bad electrical connections are the cause of electrical leakage...rarely blow a fuse.
Post by Deleted on Sept 12, 2016 9:50:39 GMT -5
My batt read 14.5 volts this morning let it idle for 5 min turned it off because of the roller weight rattle came bac 5 min later no type of electrical power fuse looks black but not broken however I haven't changed it since I bought it 6 months ago. I have mentioned this before...voltage reading is no indication of the health/condition of your battery. A real battery tester places a load on the battery and this is the ONLY way to tell the condition. Didn't you have this tested at an auto parts place and they told you it was bad? Also, you should never crank the engine with the starter for more than 5 seconds at a time. If it does not fire after 5 seconds...you wait a minute or two...then try again. Cranking the engine for 30 seconds is going to fry your starter motor if it has not already done so. You engine should easily start up within just a few seconds of cranking the starter or, something is very wrong with your tune or you have other issues.
Post by floyd2133 on Sept 12, 2016 11:41:40 GMT -5
I have a 12 volt battery from scooter shop not stalk but I'm at work now I'm jus going to take it to the shop at 4
Post by floyd2133 on Sept 12, 2016 19:46:23 GMT -5
Sco vet 90 gyro n me pirate thanks. I changed fuse up n running its at the shop however acceleration is real low. Prolly a cost me 200 at the shop . I asked for my new muffler to be put on. A new variator fan and rolls. 65$ hr x2 plus parts real quick not off eBay
Post by acvw74 on Sept 12, 2016 20:32:29 GMT -5
Glad you got it running! Probably slow acceleration due to the roller weight issue.
Post by gsx600racer on Sept 13, 2016 2:14:12 GMT -5
Damn, $65 a hour. I think I need to charge more. I just charged a guy 20 bucks to install a new throttle cable.
Post by Deleted on Sept 13, 2016 10:54:00 GMT -5
Post by floyd2133 on Sept 13, 2016 11:19:31 GMT -5
Naw I told them to do it
