Post by floyd2133 on Sept 10, 2016 6:29:18 GMT -5
I made a gasket threw the intake mani. Still wontcrank only turn over. Gas is getting to the carb. I have spark. Jus changed drive belt 779. Battery good. High performance CDi n coil week old NEW. It worked even with belt broke . Took off belt . Put 26 mm carb on it . Didn't work. Put new belt on . Then old 18 mm carb no work still videos n pics in post please respond thanks
Post by floyd2133 on Sept 11, 2016 8:24:44 GMT -5
Drive belt installed now it is making clanking sounds like cutting plastic machine video here
Post by floyd2133 on Sept 11, 2016 8:29:58 GMT -5
When I put the belt on the variator it jus slipped over. now it's rattling when I start it. youtu.be/SxT7eIjLYKg
Post by acvw74 on Sept 11, 2016 8:42:20 GMT -5
I would pull the CVT cover off...see if anything looks loose
Post by floyd2133 on Sept 11, 2016 9:07:56 GMT -5
Would bad roller weights make a rattle sound after belt change?
Post by acvw74 on Sept 11, 2016 9:33:37 GMT -5
Possibly, but it almost sounds like the starter bendix or the variator nut is loose.
Post by floyd2133 on Sept 11, 2016 11:15:34 GMT -5
I never removed the variator nut however what could be wrong with the starter bendix It went from starting to jus barley turning over youtu.be/Uoo9F6gt6Lg
Post by acvw74 on Sept 11, 2016 11:29:13 GMT -5
How did you change your belt? The starter bendix might not be installed correctly.
Post by floyd2133 on Sept 11, 2016 11:54:29 GMT -5
I use this method by just sliding the belt over m.youtube.com/watch?v=XakWj8YM_P4In addition kick start isn't working really sometimes it makes a loud cranking sound n gets stuck I press the push start and it pops back up
Post by floyd2133 on Sept 11, 2016 11:55:31 GMT -5
However when charged more it turns over better but even at 13 volts it has yet to fire up today
Post by floyd2133 on Sept 11, 2016 12:51:22 GMT -5
Post by acvw74 on Sept 11, 2016 13:37:57 GMT -5
Floyd, You have had something rattling around inside your cover...all your fins are gone off the variator fan. At some point you will want to replace that.
As a word of caution....be very careful trying to start by holding the bendix (FYI not something I would try)....if the motor would start your fingers are in a place that could cause a sever injury!! I know it can be frustrating...but not worth getting hurt...then you might not be able to ride!
Post by acvw74 on Sept 11, 2016 13:54:02 GMT -5
I use this method by just sliding the belt over m.youtube.com/watch?v=XakWj8YM_P4In addition kick start isn't working really sometimes it makes a loud cranking sound n gets stuck I press the push start and it pops back up This method is tough on the 139qmb's....I can't make it work on my, but it could be possible that a roller fell out of the ramp....I would think you might have some vibration.
Post by Deleted on Sept 11, 2016 14:27:16 GMT -5
As a word of caution....be very careful trying to start by holding the bendix (FYI not something I would try)....if the motor would start your fingers are in a place that could cause a sever injury!! I know it can be frustrating...but not worth getting hurt...then you might not be able to ride! Yes, that fan is a fan no more and will cause overheating of the cvt system unless there is additional venting as some folks are doing. Scrappy's has them for like $3. I just had to get another one myself after my variator nut came off while riding. I will admit that is not much of a fan to begin with but, remember, these are cheap Chinese scoots and if they could have shipped scooters without that fan, they would have as it would have been cheaper to do so. I have vented my cvt with some holes but, I want to really open it up soon. I would NEVER try to start my scoot with my fingers holding one end of the Bendix. That is nuts man. Bill
Post by floyd2133 on Sept 11, 2016 14:27:26 GMT -5
Ya I think that's were all the rattling is coming from the variator n rollers. Plenty vibration. It started this morning idled then went for a test drive died instantly. Also I haven't got it able to start since. I think Ima have to remove the variator but I don't have the flywheel lock yet
