Post by gsx600racer on Oct 31, 2016 20:14:12 GMT -5
Are you able to bypass the key switch to enable power to the stating circuit? So if you turn the key to on/or bypass without the key, does the rear tail light will come on and if you squeeze the brake lever does the rear brake light will come on too? If not, the fuse may be blown. If the fuse is ok, the switches in the brake levers may not be working. They need to be working to enable the electric starter circuit. If you have power to the rear light and the brake light come on when you squeeze the brake levers, then the stater button is bad or starter solenoid is bad. Starter circuit flow
Post by floyd2133 on Nov 1, 2016 1:10:16 GMT -5
I don't have a key . It only cranks by kick or bridge. It doesn't light up wen the brakes are pressed and left rear brake is faulty
Post by eclark5483 on Nov 1, 2016 1:12:41 GMT -5
Check brake light, some scoots are wired into them so that they wont start if the bulb is bad.
Post by floyd2133 on Nov 1, 2016 1:16:33 GMT -5
Post by eclark5483 on Nov 1, 2016 2:01:56 GMT -5
Damn dude, is that brake even attached?
Post by floyd2133 on Nov 1, 2016 6:08:00 GMT -5
Damn dude, is that brake even attached? It broke off from the handle bars
Post by eclark5483 on Nov 1, 2016 13:41:23 GMT -5
There is a microswitch connected to it that activates the bridge to start the bike when it is depressed. That might very well be the problem. You'll wanna get that fixed first, then worry about why it's not starting. Plus, YOU NEED BRAKES!!!! Might just fix 2 problems at once.
Post by floyd2133 on Nov 1, 2016 14:59:42 GMT -5
Damn dude, is that brake even attached? No it broke off Ima post a pic soon
Post by floyd2133 on Nov 1, 2016 15:00:13 GMT -5
Also ignition is gone I'm buying a new one is this a easy fix it's hot wired
Post by floyd2133 on Nov 1, 2016 15:01:11 GMT -5
Why is it that it doesn't start with kick after sitting for a while.
But after I jump solenoid n turn off it starts
Video in next oost
Post by floyd2133 on Nov 1, 2016 15:05:52 GMT -5
Post by Deleted on Nov 1, 2016 15:26:21 GMT -5
I think you answered you're own question.
Post by eclark5483 on Nov 1, 2016 15:41:58 GMT -5
Yeah, looks like the problem is that broken brake. Its not letting the safety microswitch engage to allow it to start. You can get a replacement from Amazon.
Post by gsx600racer on Nov 1, 2016 16:06:34 GMT -5
Maybe this guy can help you out with bypassing the key switch.
Post by floyd2133 on Nov 1, 2016 19:03:22 GMT -5
Well I got the kick start to work with reving the throttle. However it dies under full throttle and goes slow. Any suggestions ?
