Post by floyd2133 on Nov 3, 2016 18:27:55 GMT -5
The front wheel needs to be spinning. The speedometer & odometer are connected to the front wheel via the speedometer cable. Unless you are running it on a treadmill you will have to take it for a ride, preferably outside. Them walls will come up quick indoors. lol I got the screen door open bro
Post by gsx600racer on Nov 3, 2016 18:59:29 GMT -5
The front wheel needs to be spinning. The speedometer & odometer are connected to the front wheel via the speedometer cable. Unless you are running it on a treadmill you will have to take it for a ride, preferably outside. Them walls will come up quick indoors. lol I got the screen door open bro Cool, Safety First. You got the engine running, thats half the battle. As for the rest of the things that are not working. My best advise is to replace the ignition/key switch, vs hot wiring it to work. Its easy to short something out and blow the fuse. Once you replace the key switch and check the fuse,(usually located near the battery) I think all the other electrical issue should go away.(unless the wiring has been altered or messed with). Your RPM, fuel gauge, turn signals, horn, and rear tail light needs 12v from the battery to work, and that power is controlled by the key switch.
Post by floyd2133 on Nov 3, 2016 20:00:11 GMT -5
lol I got the screen door open bro Cool, Safety First. You got the engine running, thats half the battle. As for the rest of the things that are not working. My best advise is to replace the ignition/key switch, vs hot wiring it to work. Its easy to short something out and blow the fuse. Once you replace the key switch and check the fuse,(usually located near the battery) I think all the other electrical issue should go away.(unless the wiring has been altered or messed with). Your RPM, fuel gauge, turn signals, horn, and rear tail light needs 12v from the battery to work, and that power is controlled by the key switch. This is what is being bought anything else you recommend?
Post by gsx600racer on Nov 3, 2016 20:21:12 GMT -5
Cool, Safety First. You got the engine running, thats half the battle. As for the rest of the things that are not working. My best advise is to replace the ignition/key switch, vs hot wiring it to work. Its easy to short something out and blow the fuse. Once you replace the key switch and check the fuse,(usually located near the battery) I think all the other electrical issue should go away.(unless the wiring has been altered or messed with). Your RPM, fuel gauge, turn signals, horn, and rear tail light needs 12v from the battery to work, and that power is controlled by the key switch. This is what is being bought anything else you recommend? Just double check the plug/connectors match what you have. If the left and right switches come with the brakes levers(shown in picture), you dont need to buy the chrome brake lever part.
Post by floyd2133 on Nov 3, 2016 21:09:46 GMT -5
This is what is being bought anything else you recommend? Just double check the plug/connectors match what you have. If the left and right switches come with the brakes levers(shown in picture), you dont need to buy the chrome brake lever part. Ok why didn't I realize that before am I slow duh brake levers are already there
Post by floyd2133 on Nov 3, 2016 22:51:33 GMT -5
So I decided to put this 150 cc carb on my jonway it idles but won't hold under throttle vimeo.com/190200129However 50 cc carb works fine just thought I would try this . Why does it die in throttle?
Post by floyd2133 on Nov 3, 2016 22:53:30 GMT -5
Already adjusted idle n mix
Post by niz76 on Nov 4, 2016 16:09:08 GMT -5
Most 150cc carbs see 49cc scooters as beneath them and refuse to work properly when installed on one due to an (unearned imo!) sense of self importance. Just Kidding. It needs to be tuned. www.49ccscoot.com/faq/carbtune.html
