Post by benji on Nov 16, 2017 16:43:35 GMT -5
Really gotta hand it to o'verse... Dude knows how to make a good deal! I got a huge pile of parts along with the spree n jog motor. I already bought some bolts for the motor, I need to fab up a shock mount tho. I'll post pics here in about an hour or so.
Post by benji on Nov 16, 2017 20:04:56 GMT -5
Here's after I unloaded my truck. Heres the spree-a-relli all bolted together! Still need to figure out little things like a new third mount (shock mount) and I gotta do some frame straightening. Should have her running by the weekend I hope! Also got a Athena pipe and a 24mm oko pwk. Think I'm gonna try to find a bbk for cheap and make a hot rod!!
Post by benji on Nov 16, 2017 20:05:40 GMT -5
Thanks o'verse!
Post by 'O'Verse on Nov 16, 2017 20:13:25 GMT -5
Your welcome sir. After you headed out last night. I remembered the motor mount bolt. Glad you got it together so quickly. I’m pretty sure you’ll be content with the motor. It’s definitely got all it’s pep still in it. I was gonna weld a shock mount onto the spree frame. But the material so thin in the back. It would have just blown threw. 👍
Post by benji on Nov 16, 2017 21:00:47 GMT -5
Ya, the frame is so little and it's hard to see a good place for it to go. The spring action would just work away at the metal in the back until it broke off. I think I'm gonna go hard tail and just bring a flat piece if steel from the block at the shock mount all the way up to the frame, then put a 90° bend in it so it sits under the frame and "supports" it. And remove the front springs of course. And probably squirt it with white spray paint. Weekend custom ratbike build!
Post by PIG on Nov 16, 2017 21:19:44 GMT -5
What size motor is that?
Post by benji on Nov 16, 2017 22:28:22 GMT -5
Shortcase jog, just found out about an hour ago it's a bbk! Some 'senchen' bore. 70cc I think. Unless it's a 90, but I don't think so.
Post by benji on Nov 16, 2017 22:51:24 GMT -5
So🤔 tomorrow, all I got left is plumbing the fuel and oil lines, and collecting up an airbox and some carb parts (top, slide, needle,etc), and fabbing up a rear brace to replace the shock. Then fire it up. After she's running, I gotta get some paint and bomb this thing and get a seat cover too (maybe).
Post by benji on Nov 17, 2017 20:47:10 GMT -5
Here it is, in all it's glory. A jog motor crammed up the butt of a spree. I'm gonna go premix for now even tho I've got a spree oil tank and the jog motors got a pump. I added a rear brace where the shock was, and bent it so it attaches under the frame. Should be firing it up tomorrow maybe.
Post by 'O'Verse on Nov 17, 2017 20:57:10 GMT -5
Shortcase jog, just found out about an hour ago it's a bbk! Some 'senchen' bore. 70cc I think. Unless it's a 90, but I don't think so. I had a suspicion that it had a 70cc bbk on it. It definetley ripped like a 70. One of the shocks I gave you was like a 315mm so if you go back to that route you should be good. I'm just gonna guess and say 50mph as is when you get running. Also the engine came with the Polini air filter on it. Might be jetted for that filter.
Post by benji on Nov 17, 2017 22:35:12 GMT -5
I may swap to that polini. I put a different carb on there cuz I didn't have a slide or top to the one that came with it. I'm gonna try to run it with a stick box and muffler. I may swap to the Athena pipe on it for fun tho.
Post by 'O'Verse on Nov 19, 2017 15:30:01 GMT -5
I could never get the Athena to run on anything smaller than a 70cc. Maybe because the carb size and intake size. If you have another silencer laying around with a bigger exit hole I'd use it regardless. You pretty much have a stage 6 pro or pro replica with the Athena. Off the top of my head can't remember which exactly. Look at this it'll tell you www.tuningmatters.com/reviews/exhausts/scooter-tuning-exhaust-test/
Post by benji on Nov 19, 2017 16:10:16 GMT -5
Post by benji on Nov 19, 2017 16:23:14 GMT -5
This thing is FAST. Like crazy fast off the line haha. Its like a kids bike with a jog motor. It pulls the front wheel a little and even breaks the rear tire loose every now n then! I guess a 100lb bike with a bbk sure can fly!
Post by 'O'Verse on Nov 19, 2017 18:17:59 GMT -5
So let me get this str8. You sold one scoot for $400. And then took half of that and bought a faster scooter. I'd say that constitutes the definition of flipped for sure. Have you hooked up a tach to it yet?
