Post by andrikink on Apr 21, 2014 0:22:53 GMT -5
Its liquid cooled. Carlsalter.com there you can find user manuals and even malaguti manuals.
Post by andrikink on Apr 21, 2014 0:24:45 GMT -5
If you could find manual for Malaguti F15 then its okay. Ignition switch is okay, nothing bad there.
Post by andrikink on Apr 21, 2014 13:02:34 GMT -5
If i measure how many volts i get from lights when they are lighted, would it be helpful?
Post by 2stroked on Apr 21, 2014 15:03:31 GMT -5
So, its a liquid cooled F15? Never seen that exact scoot, but they all have a similar charging system. U could check the draw from the light system. It honestly it sounds like a intermintent short. Can u post a pic of ur scoot? Just for curiousity's sake? I
Post by andrikink on Apr 21, 2014 15:50:25 GMT -5
i was thinking, that i have a car taillight bulb there, on my scoot. the one with two wires inside bulb, one for brake light, one for just tail light. brake light uses so much energy that i could see that i brings front lights very down. and that bulb is broken, that only the brake light wire is okay, second one is shorted out or something like that. i have put the bulb in the casing where the bulb should go like that way, that only brake light is lighted up all the time, so it brings my stator energy very down, so i replaced the bulb with three very bright red colored LED's, the ones with resistors installed already. heres a new pic too, new color etc.
Post by 2stroked on Apr 21, 2014 16:14:21 GMT -5
Sharp,sharp, sharp! The taillight circuit may be ur problem. I love ur ride. U may need to check that brake llight circuit, to see why it pulls so much juice. Check for continunity in the wires
Post by andrikink on Apr 21, 2014 16:17:24 GMT -5
i will see whats problably wrong with it
Post by andrikink on Apr 22, 2014 12:17:27 GMT -5
Today i went to talk to very smart scooter technician, who thinks that one wire from light switch makes contact with frame. When i get home i definately check that out, pity that i have to remove all fenders to check wires what you guys think, is the wire possibly makes contact with frame? It won shorten out anything and all heat just goes away from wires then its not causing any burning
Post by 90GTVert on Apr 22, 2014 12:37:00 GMT -5
You said it first happened after washing the scoot. Makes me wonder if something is still wet and shorting somehow. Maybe moisture inside a switch assembly or something. Not totally sure how it would happen since the lighting and ignition systems should be basically separate, but it's usually best not to ignore conditions that could be a part of the problem.
Sweet scoot BTW.
Post by andrikink on Apr 22, 2014 13:08:43 GMT -5
I'll definately take a look inside handlebar console and other wires. Thank you!
Post by 2stroked on Apr 22, 2014 15:03:25 GMT -5
You said it first happened after washing the scoot. Makes me wonder if something is still wet and shorting somehow. Maybe moisture inside a switch assembly or something. Not totally sure how it would happen since the lighting and ignition systems should be basically separate, but it's usually best not to ignore conditions that could be a part of the problem. Sweet scoot BTW. Thats what I thought too Brent, but andrikink said the harness had been fooled with. Maybe someone tapped tge wrong source for the light circuit. That would kibda cause the lights to draw from the ignition power. Wouldnt it? also I hinted at bare or broken wire earlier. hope u find the gremlin!
Post by 90GTVert on Apr 22, 2014 15:06:15 GMT -5
If it's DC CDI it could for sure. AC CDI I'd think it wouldn't matter, but electrical stuff confuses me at times (most times lol).
Post by andrikink on Apr 22, 2014 16:04:17 GMT -5
Dont even know myself that is it a DC CDI or AC. Lights are getting power according wiring diagram so they wont take energy from wrong place.
Post by andrikink on May 9, 2014 11:01:39 GMT -5
Hey! So got some news for you . When before the problem was at top end rpms then now its sputtering while accelerating. Strange is that when riding witch cold engine then at first when you start the bike up it sputters because of the cold engine, and when accelerating again then everything is fine. Its just getting worse and worse with just driving and when engine gets hotter. Without lights- no problem. Tried another CDI aswell, first thought that i solved the problem but hey, its not that easy . When started up my bike after workday today, then juggling the spark plug gap i got shocked several times, dont know how. I had another gap in my boot so tried that one, didnt get any electrical shock anymore .
Post by andrikink on May 9, 2014 12:06:19 GMT -5
And im suspecting stator. It could be faulty aswell. Someday i'll take it apart and maybe resolder connections. Its onething that i havent tested yet and where ignition and lights are together.
