Post by Jwhood on Jun 10, 2014 17:45:36 GMT -5
So I put 75 m.j and she is doing ok just took it for a little cruise no loss of power but it won't let me adjust idle still I'm lost I think it was cause my airbox wasn't on new car tight and she was leaking air I did your air box mod and she is sealed good now and my pipe was loose at head and she was sucking to much air can't figure out the carb adjustment now??
Sent from my HTC6600LVW using proboards
Post by 90GTVert on Jun 10, 2014 18:03:41 GMT -5
Screw it all the way in and let it sit there for a minute and settle, then screw it way out and let it settle. If it doesn't respond either way the pilot jet may need to be changed or the carb needs to be cleaned.
Post by Jwhood on Jun 10, 2014 18:09:41 GMT -5
Yeah I just did a massive carb clean and it wasn't that bad,I will tomorrow do the screw all the way in tomorrow and let u know what I come up with, it started freaking raining that air box mod of yours works great and by the way u might want too add that you can get spa/ pool vaccum hose at home depot for $4.00 a foot and I used a craps load of jb weld also to secure new metal flange too the oem airbox
Post by 90GTVert on Jun 11, 2014 7:07:26 GMT -5
I added those notes. Thanks.
Post by Jwhood on Jun 11, 2014 14:57:12 GMT -5
So got home from work I tried to adjust the needle and brought it to the top slot but around 25 mph started bogging out what should I set it at here is picture of my needle,it won't let me post pics my needle has 5 slots,I moved it down to slot 3 gonna try now
Post by 90GTVert on Jun 11, 2014 15:10:17 GMT -5
Where was the needle? Move it one step at a time and see what position works best. This stuff is trial and error to some degree. Can't just pick the right one first try in most cases unless it's already close. The top clip position is the leanest, least fuel. The bottom clip position is the richest, most fuel. Primary area of effect is 1/4-3/4 throttle for the needle, but it can have some effect on idle or WOT.
Post by Jwhood on Jun 11, 2014 15:30:09 GMT -5
Ok moved the needle to 3 rd up from bottom and got up to 30 -35 with a little hesitation but better then top I still can't adjust screws at all no change when I screw them do u think my reeds might of we t bad there the original metal ones that came with bike,Damn thing is driving me nuts,the needle original position was all the way at the bottom and I didn't even mess with that that's how it came from partsforscoorers
Post by 90GTVert on Jun 12, 2014 9:24:57 GMT -5
You can check the reeds. If they don't seal it will run rich. You can hold the reed assembly up to light and see if any light gets through. If it's a sliver of light sometimes you can flip the reed petals over and they'll work fine.
Post by Jwhood on Jun 12, 2014 12:46:07 GMT -5
Ok I'm going too go out and see if there bad it's a bitch getting too them but I wanna make sure it's not them I'll let you know the out come of it when I'm done
Post by Jwhood on Jun 12, 2014 14:04:51 GMT -5
Here is reeds they are pretty bent and gasket is shot I think I'm gonna order a performance intake and carbon fiber reeds any recommendations on where too buy them from here is pic of reeds... www.dropbox.com/s/9diwia6mueiv7rd/IMAG0130.jpgSent from my HTC6600LVW using proboards
Post by 90GTVert on Jun 12, 2014 16:04:57 GMT -5
Yeah, that's a problem. I'm not sure where a good source is for those. When I search I either get reeds for the Minarelli engine or the ones that come up that look like yours are overseas. Maybe someone that deals with TGB can give you a good source? If all else fails you can order carbon fiber reed material sheets and cut your own.
Post by Jwhood on Jun 12, 2014 17:32:16 GMT -5
Damn scooter is crazy took everything apart bought some gasket material and replaced the gasket under intake flipped the reeds around even looked at piston and cylinder to see if they where the culprit but all was good even took the Mrp pipe off and put back oem pipe she fired up ran good for about 5 mins then the full throttle bogging started again don't understand what is going on was even getting response from screws while adjusting the idle air file mixture and I'm just stumped there are no good scooter mechanics up here in parkville md,where do you live at???I'm half tempted too come too you too help me fix this Damn thing!!lol
Post by 2TDave on Jun 12, 2014 20:08:28 GMT -5
Those reeds looked pretty bad. I'm not sure flipping them will help as the sides won't seal.
Post by Jwhood on Jun 12, 2014 21:25:49 GMT -5
I actually put them down on a board and flatten them back out,I also just went back out too my garage and drained all the gas and I'm going too put some fresh gas and some isoheet in and see if that helps tomorrow!!
2007 tgb key west,with motoforce 50cc replacement cylinder head &piston,Mrp racing pipe and 19mm carb and a small tachometer!!!!
Post by Jwhood on Jun 14, 2014 10:20:03 GMT -5
Got me a new exhaust gasket today and exhaust studs had an exhaust leak that might of bein the culprit also of the bike running like craps will post findings also ordered some carbon fiber reeds
