Post by jareeb on Feb 4, 2015 13:05:51 GMT -5
just ordered the sportpro mk2 clyinder, doppler sr2 reedcage, and a set of three motoforce centra springs. plan on gasket matching the cylinder as far as porting. might do a few things to the ports after i see what timings they are at. came to $215 shipped with the 5% off. very excited!!
Post by 2strokd on Feb 4, 2015 13:10:17 GMT -5
What crank is in this wild mina mill of your mighty Spree!?
Post by 2strokd on Feb 4, 2015 13:14:55 GMT -5
If its stock ide save yourself the grief of having to tear it down when you finally get a good pipe and it hits into the 11,000RPM peak power range and toasts the stock crank (if you are running one?) and ruins the new kit. Ask me and other members about those stock cranks and 10,000+RPM for very long.. Just my 2 tho This puppy here is a great deal! It will get you a baby stroker with that MKII Sport it will be a beast and stay together! Ive gotta cylinder spacer for a 47mm already cut i might come off of as well? 49ccscoot.proboards.com/thread/11191/ruima-4mm-stroke-10mm-crankshaft
Post by jareeb on Feb 4, 2015 13:32:15 GMT -5
damnit damnit! i need to change my order with scootertunin.ca
i dont have a small spline hoca tho. and i really dont want to buy another. but i think i will. i will need to mill the cases for this crank? also what cc will it come out too.
edit: sent an email to scootertuning.ca seeing if they will swap out pistons for a 10mm guess im going mini stroker!
Post by 2strokd on Feb 4, 2015 13:53:38 GMT -5
That crank is a drop in i think?
Post by jareeb on Feb 4, 2015 13:56:00 GMT -5
its not a big deal if its not. but better. what bearings/seals do you recommend? where would i find that spacer and stud kit?
Post by 2strokd on Feb 4, 2015 14:14:47 GMT -5
Post by 90GTVert on Feb 4, 2015 14:58:22 GMT -5
Post by jareeb on Feb 4, 2015 18:13:53 GMT -5
How big should the spacer be?
Post by 90GTVert on Feb 4, 2015 21:59:26 GMT -5
If you don't need everything right in front of you at once you can get the crank and cylinder and play around with shims/washers under the cylinder to figure out what thickness would get you the results you're looking for and then buy a spacer or material to make one.
Post by jareeb on Feb 4, 2015 23:25:12 GMT -5
Thats what came to mind while I was at work. Best place to order 1/8 mandral burrs for a dremel cases are getting trenches now.
Post by jareeb on Feb 5, 2015 12:48:28 GMT -5
super impressed with scootertuning.ca they allowed me to change my order to get a kit with a 10mm. now for the parts to start flowing in. and ill hopefully get the cases halves apart tomorrow.
Post by jareeb on Feb 6, 2015 14:32:21 GMT -5
Crank showed up today. Thanks Jason. Now just waiting on other parts.
Post by jareeb on Feb 10, 2015 12:41:48 GMT -5
Post by oldgeek on Feb 10, 2015 14:56:06 GMT -5
Ohh...thats a purdy cylinder! Ima hafta get me one someday.
