Post by jareeb on Feb 10, 2015 18:39:53 GMT -5
Its very pretty. Kind just wanna use it as a cool paper weight lol
Post by 190mech on Feb 10, 2015 20:17:09 GMT -5
All 'hot rod' cylinders end up as paper weights!!
Post by dude on Feb 10, 2015 20:24:58 GMT -5
What carburetor are you going to use?
Post by jareeb on Feb 10, 2015 23:25:51 GMT -5
Dont say that !! Lol im using a 19mm dellorta
Post by jareeb on Feb 12, 2015 12:19:02 GMT -5
no crank bearings or burrs till the 17th. so lets talk about what jet range i would need. i was thinking around 120s? also i am not sure where to start on the pilot jet the one in the clone dell has no numbers on it so i dont even have a starting point.
Post by jareeb on Feb 18, 2015 12:33:31 GMT -5
got the cylinder to top of cases matched. also started the trenches. no pictures but ill get some later. also got the crank bearings. they sent me a set of china sealed bearings those are being made into slip mock up bearings now. so ill find some good jap bearings to actually put in.
Post by 2TDave on Feb 18, 2015 18:51:44 GMT -5
Brent recommend vxb.com to me awhile ago and I've been happy with them.
Post by jareeb on Feb 18, 2015 23:29:49 GMT -5
Okay I dont know the part numbers either
Post by 2TDave on Feb 19, 2015 6:29:05 GMT -5
I think you can search by size. If not you should be able to find a size to # chart online.
Post by 90GTVert on Feb 19, 2015 10:03:56 GMT -5
Post by jareeb on Feb 19, 2015 12:43:25 GMT -5
Post by jareeb on Feb 19, 2015 12:44:22 GMT -5
Post by 190mech on Feb 19, 2015 12:54:28 GMT -5
Thats some REAL soft stuff!6061T6 is easy to work with but much stronger..
Post by jareeb on Feb 19, 2015 13:25:52 GMT -5
does that sound thick enough then?
Post by 90GTVert on Feb 19, 2015 13:42:30 GMT -5
thinking im going to need a 1mm spacer. piston is 1.54mm from the top of the bore and the cylinder head has a 2.5mm part that sticks into the bore. so 1mm spacer plus two gaskets should be where i want it? does that sound thick enough then? If you move the cylinder up with just the 1mm spacer you put the piston 2.54mm below deck from what you've stated. The head is step cut and will take up 2.5mm of that, leaving you 0.04mm of squish clearance without any gaskets. Guessing you'll end up going 0.5-0.7 squish? You'll need to figure out what combo of gaskets and spacer gets you there when the gaskets are compressed. That or plan on using a sealant on both sides of the spacer and get something around 1.5-1.7mm thick.
