Post by Lucass2T on Mar 5, 2015 13:48:20 GMT -5
never machine a nikasil bore top as the nikasil is lapped over the top to keep it from flaking off. Thats very good to know! Have the same problems with my metrakit 70cc!
Post by jareeb on Mar 7, 2015 20:06:43 GMT -5
engines all together. order a new hoca var. jets, hopfully running this week!!
Post by jareeb on Mar 9, 2015 9:52:32 GMT -5
Squish is at .30mm so im thinking a base gasket under the spacer I made would put it around .7mm
Post by jareeb on Mar 9, 2015 9:57:56 GMT -5
Anyone have an extra base gasket they could send me? Id rather not pay $30 from scootertuning
Post by 2TDave on Mar 9, 2015 10:19:42 GMT -5
I've got some S6 base gaskets at home. I'll check what thicknesses and let you know.
Post by jareeb on Mar 9, 2015 10:36:07 GMT -5
Thank you.
Post by 190mech on Mar 9, 2015 11:24:48 GMT -5
Post by jareeb on Mar 9, 2015 12:19:50 GMT -5
its an o ringed head. and the way ill have it is a base gasket - spacer - base gakset - cylinder.
Post by 2TDave on Mar 9, 2015 17:19:34 GMT -5
I've got a S6 MkII paper gasket. It's .54mm. Don't have any aluminum shims to spare but they come in varying thicknesses from S6. I also have a Hoca 47 mm gasket that came with an o-ring from partsforscooters.com. It could be trimmed to match if you needed an o-ring also.
Post by 190mech on Mar 9, 2015 19:04:43 GMT -5
its an o ringed head. and the way ill have it is a base gasket - spacer - base gakset - cylinder. 2 gaskets,is 2 gaskets,no matter how you stack them!Choosing a thicker aluminun spacer and 1 gasket with a sealer would be a better choice,,No gaskets with sealant and proper spacer would be even better!!
Post by jareeb on Mar 9, 2015 19:57:20 GMT -5
Im gona see what thickness my parts store has. I dont wanna be waiting on parts but ill let you know tomorrow. Shoulda just made a 2mm spacer then. Haha
Post by 2strokd on Mar 10, 2015 9:37:15 GMT -5
Only way ive gotten more than one to work is if i glued them together and let it set before even using it.
If it were me and its not gonna settle anymore ide try .3mm if its a 70cc race engine. My 95cc is set at .4mm now.
Edit: Drag race engine...
Post by jareeb on Mar 10, 2015 10:54:35 GMT -5
nope its a daily driver. so i wana keep it loose.
Post by 2strokd on Mar 10, 2015 13:44:38 GMT -5
nope its a daily driver. so i wana keep it loose. For sure then! Why not run a gasket on each side of the spacer John? Ive done so.. With the proper torque specs and a good, new gasket i dont think this is a problem. Also, even though its a o-ring head, you can ditch the o-ring for a .50mm copper head gasket and it will seal
Post by 190mech on Mar 10, 2015 14:19:54 GMT -5
Heck,its worth a try..I'd recheck the head torque a couple times just to make sure its not settling..
