Post by Elektrey on Aug 29, 2015 16:53:00 GMT -5
Might as well do a write up.
First thing I did was take a sharpie (silver to write on the black plastic) and make a rough sketch of where I wanted to the hole to be. You can use isopropyl alcohol to remove the sharpie and alter the lines.
Do this until you are happy with it. Make sure to measure the size you need for the cutout, and draw about 80% of that size with the sharpie.
Then take a boxcutter and a torch and heat it up real good, get the tip to glow orange. I shook it/blew on it after heating it up so it wasn't on fire, and then start cutting the sharpie outline with the knife. Push the knife in and it should cut the plastic like butter. Make sure you know what is behind the plastic before you start cutting! don't want to cut wires or melt anything with the blade.
After you cut all over the outline, it should pop out pretty easily.
From here I used a file and filed down the rough edges, but I don't think this is absolutely neccesary.
After I got the rough shape cut out with the knife I used the knife to make each edge straight by sort of "carving" out each side. After each side was pretty straight and I was satisfied I took the display and put it in the hole and saw how much I needed on each side for it to fit.
I did top to bottom fitment first. Look at it from a few feet back and see which way would be better to expand the hole (up or down). I cut mine out down. I took a small (0.5-1.5mm) carving from the bottom line and then put the display in to see if it would fit. Eventually I got the hole big enough to fit height-wise.
I did the same steps for the length and then once both fit I tried pushing the panel into the hole. It might help to examine the corners and open them up a little to get the whole thing to fit in.
It eventually just pushed in and looks great! Real tight fit too. It has tabs on the sides to keep it locked in, but It would have stayed put with just the tolerance fit I gave it anyways.
Heres the initial cut
final cut
Here it is fit in the hole
and from the back
Just need to hook up the connector that I wired yesterday:
EDIT: I put it in upside down lol, going to go fix it.
final cut
and from the back
