Post by moofus02 on Oct 27, 2014 20:45:42 GMT -5
What size is the piston in that? 47.6?
Post by niz76 on Oct 27, 2014 20:49:22 GMT -5
I'm looking all over Google images and can't seem to find a pic of this piston. I think there should be a tab there at the intake side? It does look jagged like a piece is broken off...
Post by niz76 on Oct 27, 2014 20:50:27 GMT -5
What size is the piston in that? 47.6? Sent from my SPH-L720 using proboards Yes 47.6
Post by Sitticuss on Oct 27, 2014 20:53:50 GMT -5
I've got a 47.6mm piston and rings new in the box.... and i still owe you i'll send it out
Post by moofus02 on Oct 27, 2014 20:55:49 GMT -5
I've got a47.6 2 ring 10 pin need a 12 pin. I've got a link for piston somewhere at a reasonable price
Post by moofus02 on Oct 27, 2014 20:56:54 GMT -5
Looks like problem solved lol
Post by niz76 on Oct 27, 2014 20:57:35 GMT -5
I've got a 47.6mm piston and rings new in the box.... and i still owe you i'll send it out Heck I'll take it Sitticuss if u don't need it. Just let me know the difference $$.
Post by niz76 on Oct 27, 2014 20:58:52 GMT -5
I'm thinking a dual ring setup would be better? Does the single ring "racing piston" make that much of a difference??
Post by 2TDave on Oct 27, 2014 21:01:16 GMT -5
Brian I've got a 12 pin and rings. Not sure if it's 47 or 47.6. I'll check in the am and let you know.
Post by Sitticuss on Oct 27, 2014 21:03:11 GMT -5
I've got a 47.6mm piston and rings new in the box.... and i still owe you i'll send it out Heck I'll take it Sitticuss if u don't need it. Just let me know the difference $$. Got it as a spare when i was running the other motor in my scooter before i switched to the 90cc. So it's just collecting dust. I'll send it out tomorrow
Post by niz76 on Oct 27, 2014 21:45:22 GMT -5
Heck I'll take it Sitticuss if u don't need it. Just let me know the difference $$. Got it as a spare when i was running the other motor in my scooter before i switched to the 90cc. So it's just collecting dust. I'll send it out tomorrow U tha man!
Post by Elektrey on Oct 27, 2014 21:54:14 GMT -5
I know you buy these things knowingly broken but do you ever bring along a compression tester to check that? Or even a magnet to stick in the fuel tank to see if any rust comes out or things like that?
Post by moofus02 on Oct 27, 2014 22:01:00 GMT -5
I know you buy these things knowingly broken but do you ever bring along a compression tester to check that? Or even a magnet to stick in the fuel tank to see if any rust comes out or things like that? That would take all the fun out of it Sent from my SPH-L720 using proboards
Post by Sitticuss on Oct 27, 2014 22:06:04 GMT -5
I know you buy these things knowingly broken but do you ever bring along a compression tester to check that? Or even a magnet to stick in the fuel tank to see if any rust comes out or things like that? We just figure its messed up and decide based on the price
Post by niz76 on Oct 27, 2014 23:11:28 GMT -5
I know you buy these things knowingly broken but do you ever bring along a compression tester to check that? Or even a magnet to stick in the fuel tank to see if any rust comes out or things like that? Nope! Only thing I kinda dread is getting another with a bad crank- even in that case I have a $75 parts scoot...
