Post by moofus02 on Oct 30, 2014 17:31:52 GMT -5
I think it has a rev limited cdi. Some didn't have a wire to cut and you had to change cdi to De restrict. You are getting more speed from that before you hit the limiter than i was. That one could have better gears than the standard 13.5. Maybe they changed gears trying to gain speed mine cut out at about 30 by speedo
Post by 190mech on Oct 30, 2014 18:54:56 GMT -5
Ive had those VW filters kick my a** more than once,,They are designed for pressured fuel,not gravity!Throw that filter away and get a screen type..
Post by Sitticuss on Oct 30, 2014 19:07:39 GMT -5
those filters are junk..I thought you mounted it in the opposite direction. only filter i had seperate and start leaking fuel everywhere.
Post by jhobe6678 on Oct 30, 2014 19:09:53 GMT -5
Agreed. I have screen filters on both my scoots and have never seen a gas flow issue with either of them. Both are using vacuum petcocks too, which will change to manual in time.
Post by niz76 on Oct 30, 2014 22:44:58 GMT -5
Didn't get much time with the scoot today. I did take it for a spin this evening and got a few more clues- For a minute or two while scoot was still cool it actually performed well- and fast!- halfway through my neighborhood it started breaking up again and also got a little backfiring on de-throttle. Air leak? Too lean?? I scoured the scoot for air leaks- The only maybe/possibly leak I could even find a hint of is possibly at the exhaust manifold. Close inspection with a bright flashlight while laying on my back and I'm still not positive it's leaking but I plan to take it off tomorrow and re-do it to be 100% sure. I also sealed the airbox where the elbow pops in and these forward intake airboxes all seem to have the same problem of the elbow popping out too easily. Went up to a 90mj from 85 and that's about all I got done. I have a pancake filter and manual fuel shutoff so I'll be putting those in tomorrow... I'm almost positive the CDI isn't restricted as I have on occasion gotten this to rev and run correct at high RPM for a few seconds at a time... The CDI will be my last effort after I've exhausted every possible cause for high RPM "break-up."
Post by moofus02 on Oct 31, 2014 6:33:38 GMT -5
If you get it to run at high rpm for a few before it breaks up you are probably right. The cdi would be consistent. Likely fuel like you are chasing. Those are nice scooters don't fall in love lol
Post by niz76 on Oct 31, 2014 11:38:05 GMT -5
If you get it to run at high rpm for a few before it breaks up you are probably right. The cdi would be consistent. Likely fuel like you are chasing. Those are nice scooters don't fall in love lol Sent from my SPH-L720 using proboards I'm in a bit of a love/hate relationship with it right now haha. Definitely more of a challenge tuning this than the stockers! I've eliminated the petcock now with a shutoff and put the new filter in. I did take the exhaust off last night and found tiny trace of a leak- that's all sealed up good now. The only thing left is to keep carb tuning. I was hoping to fire it up this morn with the new stuff and it'd be great but no It's significantly cooler today and now it's back to more breaking up than cutting out like it was in the vid... I took the snorkel out and it seemed a bit worse. I only have a 95 and 100 mj left in my arsenal so hopefully one of those two will get 'er done!
Post by jhobe6678 on Oct 31, 2014 12:15:43 GMT -5
If you get it to run at high rpm for a few before it breaks up you are probably right. The cdi would be consistent. Likely fuel like you are chasing. Those are nice scooters don't fall in love lol Sent from my SPH-L720 using proboards I'm in a bit of a love/hate relationship with it right now haha. Definitely more of a challenge tuning this than the stockers! I've eliminated the petcock now with a shutoff and put the new filter in. I did take the exhaust off last night and found tiny trace of a leak- that's all sealed up good now. The only thing left is to keep carb tuning. I was hoping to fire it up this morn with the new stuff and it'd be great but no It's significantly cooler today and now it's back to more breaking up than cutting out like it was in the vid... I took the snorkel out and it seemed a bit worse. I only have a 95 and 100 mj left in my arsenal so hopefully one of those two will get 'er done! YOU CAN DOOOO EEEEETTTTT!!!!
Post by niz76 on Oct 31, 2014 12:30:55 GMT -5
95 and 100mj no good... "pig rich." Now going back down the ladder... the only 80mj I have is in the AIR50 scoot which is fine since I've been wanting to upjet it for the cooler weather.
Post by niz76 on Nov 1, 2014 12:30:23 GMT -5
OK so I've made a decision on this scoot- a couple decisions and a question actually...
#1: I have come to the conclusion that it IS rev limited by the CDI. I've gone up and down the jet ladder with 80,85,90, and 100 (my 95mj disappeared). Since the DC CDI's are so expensive for this (I can only find them for $75+) and I don't want to keep waiting for parts..
#2: I have decided to just put this Beamer to stock 49cc and sell it that way. I would've liked to see the full potential on this with the t6 Airsal and Technigas (it seems fast!)but in the end it's just another full frame Mina and I'll keep these goodies for something else. (Is this exhaust too small for my bone stock 90cc?)
Post by niz76 on Nov 1, 2014 12:35:18 GMT -5
Post by jhobe6678 on Nov 1, 2014 12:49:50 GMT -5
OK so I've made a decision on this scoot- a couple decisions and a question actually... #1: I have come to the conclusion that it IS rev limited by the CDI. I've gone up and down the jet ladder with 80,85,90, and 100 (my 95mj disappeared). Since the DC CDI's are so expensive for this (I can only find them for $75+) and I don't want to keep waiting for parts.. #2: I have decided to just put this Beamer to stock 49cc and sell it that way. I would've liked to see the full potential on this with the t6 Airsal and Technigas (it seems fast!)but in the end it's just another full frame Mina and I'll keep these goodies for something else. (Is this exhaust too small for my bone stock 90cc?) I can't say if that pipe is too small, all I know is when I put it on my VX50, it went from a max of 37mph to 43mph. Stock 50cc of course, I have yet to get the time or priority to put the BBK on it. In my opinion, no I don't think it would be too small but then again at this scale it's hard for me to really say.
Post by moofus02 on Nov 1, 2014 14:27:02 GMT -5
You should be able to make any 2t cdi work but will one of the kymco plug in and work workout re wiring i don't know. Yamaha vino 2t had a dc cdi but it was completely different looking and would require a wire job
Post by 2TDave on Nov 1, 2014 14:50:37 GMT -5
You would want to measure the stinger id. My guess is that it will be small for a 90 and cause you to overheat. If I recall 19mm is the minimum but confirm that with 190 or Brent.
Post by niz76 on Nov 1, 2014 16:08:02 GMT -5
You would want to measure the stinger id. My guess is that it will be small for a 90 and cause you to overheat. If I recall 19mm is the minimum but confirm that with 190 or Brent. Exactly- I'll have to do a search that info- it's somewhere around here...
