Post by Clank on Nov 28, 2014 13:53:36 GMT -5
I'm thinking you're right Brent, bad intake valve seat. Anyone know if i can you use toothpaste as a lap compound??
Post by jhobe6678 on Nov 28, 2014 14:11:20 GMT -5
Here's one from a knicked seat that shot flames from the exhaust. I bet that was a mod someone paid extra for. You know, afterburner effect.
Post by Clank on Nov 28, 2014 15:40:36 GMT -5
Well it's not the valves leaking. I did what 90GTVert suggested pouring parts cleaner in the ports. Starred at for ten minutes each port and nothing. Does anyone by chance know if the rise on the head for the rocker assembly is different for 69&64valves? The wind was getting too gnarly to work in or on an open engine.
Post by Clank on Nov 28, 2014 15:55:24 GMT -5
Guess I'm gonna check the float in the carb and get a new spark plug and see what happens. No way to get to an auto store too get a compressing tester. :censored: :banghead: :censored: :punch: :censored:
Post by jhobe6678 on Nov 28, 2014 16:36:20 GMT -5
Whatever you do, don't buy the harbor freight compression tester. I've never gotten it to work right on either of my scoots. It doesn't go above 30psi, I'm thinking it's not made for little motors.
Post by Clank on Nov 28, 2014 21:10:20 GMT -5
LIKE A BAT OUT OF HELL WITH HIS ASS ON FIRE!!!!! :riding:
Post by jhobe6678 on Nov 28, 2014 21:14:15 GMT -5
LIKE A BAT OUT OF HELL WITH HIS ASS ON FIRE!!!!! huh? What? What happened? You got it all worked out? RESULTS MAN!!!
Post by Clank on Nov 28, 2014 21:19:51 GMT -5
After I get the screw out of my foot
Post by jhobe6678 on Nov 28, 2014 21:22:24 GMT -5
After I get the screw out of my foot By all means. Please remove the piece of metal from your flesh before you post your results.
Post by Clank on Nov 28, 2014 22:54:47 GMT -5
Ok I just got done writing what happened and my phone when :zap: I'm tired and frozen I'll repost in the AM. I'm done for the day
Post by Mrx2002 on Nov 28, 2014 23:02:23 GMT -5
Ok I just got done writing what happened and my phone when I'm tired and frozen I'll repost in the AM. I'm done for the day Get some sleep man we can wait....Well I can lol i can't speak for jhobe6678
Post by Clank on Nov 29, 2014 4:38:40 GMT -5
Midnight snack. Turkey melt and Mickey's.
Post by Clank on Nov 29, 2014 5:02:13 GMT -5
Ok so valves checked for leaks: Negative Ghost Rider, both in operational order. Float bowl check; In operational order. I started blowing out all the little ports in the carb. All good till I hit the idle jet. Nothing going through so I pulled it and could not see light threw it or a valium. Whatever was inn it was inn it good. But the idle jet shouldn't affect the scoot in WOT. I swapped the A9 cam out and put the stock back in. jhobe6678 mentioned spark plug. Well it was a new plug but for shits n giggles I threw an old one I had laying around. I know the senior members are already typing "change one thing at a time!" But it was blowing 40mph and gusting 60+ mph. Not cool with an opened engine outside. I swear, if this blacktop screams any louder I'm gonna lose my F :censored: ing mind!! Got it together enough to fire it about 1830 PST. It was about 36° with a bitch of a wind chill around 22° and dark. When I took off on it I damn near fell off the back! WHOA! I don't believe it. It's three blocks to the next stop sign and it use to get up to about 25 to 30 by then. This time I watched the needle blow past 5
Post by Clank on Nov 29, 2014 5:02:36 GMT -5
I HATE THIS PHONE
Post by 2TDave on Nov 29, 2014 5:21:20 GMT -5
Nice!!! Sounds like you found the problem.
