Post by Elektrey on Dec 4, 2014 12:03:31 GMT -5
Plot twist: the odometer got stuck after 2 miles
Post by Mrx2002 on Dec 4, 2014 12:08:33 GMT -5
Plot twist: the odometer got stuck after 2 miles Haha well once i get the scoot running again we will find that out now won't we!
Post by Fox on Dec 4, 2014 12:13:43 GMT -5
You can take the speedo cable off the wheel puck and stick it in a drill to test the speedo/odo. I think you have to spin it counter-clockwise.
Post by Clank on Dec 4, 2014 13:49:16 GMT -5
Idk if it helps but that's exactly what a Taotao VIP looks like. Plastics frame they're identical copies.
Post by Mrx2002 on Dec 4, 2014 15:04:01 GMT -5
Idk if it helps but that's exactly what a Taotao VIP looks like. Plastics frame they're identical copies. Im sure that will come in handy! Thanks man! I dont think im going to get much done today its raining and cold its 28!
Post by 90GTVert on Dec 4, 2014 15:29:10 GMT -5
Hey 90GTVert did your sunl have a tach? If so was it hard getting it to work again? Mine didn't. Never owned a scoot with a stock tach, but the signal should come from the + side of the coil like any other tach I'd think.
Post by niz76 on Dec 4, 2014 15:37:22 GMT -5
Looks like a good buy! Theses are my favorite "flips"- body and seat is in good condition, just needs some elbow grease, couple parts and some know-how to get it up and running. Good luck with the new wiring harness! This scoot will have "sweat equity!"
Post by Mrx2002 on Dec 4, 2014 16:09:40 GMT -5
Looks like a good buy! Theses are my favorite "flips"- body and seat is in good condition, just needs some elbow grease, couple parts and some know-how to get it up and running. Good luck with the new wiring harness! This scoot will have "sweat equity!" Well the more i look over this scoot i dont think im flipping this one its in so much better shape than my GMW! I think this will become my daily rider and the gmw will be for friends to scoot around with me. Thats the nice thing about being single i don't have girlfriend/wife telling me "You said you were going to sale this one you can't keep it!" LOL Hey 90GTVert did your sunl have a tach? If so was it hard getting it to work again? Mine didn't. Never owned a scoot with a stock tach, but the signal should come from the + side of the coil like any other tach I'd think. Okay that sounds simple enough! Thanks man!
Post by Mrx2002 on Dec 4, 2014 20:49:05 GMT -5
W00t i haz parts!! New spark plug boot fuel/vac line for the SunL windshield 49ccscoot.com stickers Thanks 90GTVert!! New front brakes for the GMW new belt cuz i know i will need that on the side of the road someday and a CDI sleve to keep that little bugger from bouncing around on the SunL! Also some 1k clutch springs for better launchability! Windshield. Better view of teh parts
Post by Mrx2002 on Dec 5, 2014 4:26:29 GMT -5
High flow air filter racing cdi high performance coil www.ebay.com/itm/161468518575mNew kick start shaft/gear cuz mr meth head used vice grips to kick start the scoot... www.ebay.com/itm/150874849313KEI HIN carb stock carb has had meth mans "touch" as well.. www.ebay.com/itm/161154688307Carburetor Main Jets #80, #85, #90 & #95 to go with the aftermarket air filter www.ebay.com/itm/151461350804Horn cuz mine is missing and this is a MUCH needed part!! www.ebay.com/itm/321201979580Anyone have any experience with this battery? www.ebay.com/itm/331376420587QMB139/GY6 Scooter Throttle Cable 76" Handsome Boy again meth man "touch" found here... www.ebay.com/itm/170937733533Kick Starter Gy6 50cc www.ebay.com/itm/261553211770Ignition Key Set (Handsome-Boy Style) I think you guys know why by now www.ebay.com/itm/151254996886All for a grand total of $186.42 A lot of these parts i could have made work but as im keeping this scoot im looking to the future i don't want loose stripped out screws vibrating from the carb and getting sucked into the engine at 8k rpm! throttle cables that have been cut and made to work with a bolt that has been drilled out. A horn because i don't want my ass ran over etc! An some performance parts because well why not? lol everything should be here in around 5 days! *Edit* Also a few things from scrappy handsome boy rear inner fender and HB front headlight grille For a grand total of $30.43 so all in all $216.85. Meth may be cheaper!
Post by Sitticuss on Dec 5, 2014 4:35:46 GMT -5
I think i have that exact same cluster but it says baccio on it...lol
Post by Mrx2002 on Dec 5, 2014 4:48:50 GMT -5
Also do i need to upgrade the pilot jet with that airfilter? I feel like i should i mean if the main jet needs to be bigger why not that one right?
Post by Mrx2002 on Dec 5, 2014 5:51:46 GMT -5
Koso Keihin N424-21 Carburetor Carb Pilot Slow Idle Jet Kit (4 Jets) 35-42 www.ebay.com/itm/231405208208Okay these are on the way too... Think this should about do it!
Post by Mrx2002 on Dec 6, 2014 0:26:04 GMT -5
Okay another $105 down more parts and tools..I like tools Volt meter,Snap ring pliers so i can fix the kick start on the SunL,Lights for the RX50,Feeler gauges that go down to .0015 so i can get the valves just right on both scoots! Fuel filter 2 spark plugs 12 volt outlet for the SunL can O Pb blast it was on sale for 1.99!! some more gear oil for the scoots Hose clamps yep i think im good! And it looks like i will have more time to work on em because my full time job got cut to part time today... Meh i don't care. So i got some of this to drink and say F-it!! Between him and his brother Jim i should be just fine
Post by Sitticuss on Dec 6, 2014 0:46:54 GMT -5
I got a pair of snap ring pliers from advanced auto parts. They fell apart during my first build.
