Post by 90GTVert on Sept 28, 2009 14:17:06 GMT -5
You've mentioned the wiring like a major issue a couple of times, so I gotta ask what is it that makes it so hard to do the wiring on this swap? I know the ruck has an ECU, but does it control anything other than the engine? If not, why can't you wire up a stock 2 stroke harness and lengthen where needed to reach the battery, controls, whatever? That's what I had to do when I stripped my Triton to the frame and relocated components. It's really not that bad as long as what you start with isn't junk and you know how to solder.
Post by Enviromoto on Sept 28, 2009 17:41:52 GMT -5
To do it right I will have to shorten, lengthen some wires to make it one clean harness. Not only that but Im a bit worried about the charging system and how it should be hooked up. Wiring is not my strong suit but I manage. I just feel like Im rushing this project. I still need to center up the engine, build it, and all the other stuff that goes with it in 2 days. Thats why Im putting it on hold. I just dont have enough time in the day. Especially after this cold has knocked me on my ass for 3 days. No sweat thought I have 3 other scooters to chose from.
Post by 90GTVert on Sept 28, 2009 20:13:13 GMT -5
Should be pretty straight forward with the charging system... use the stock 2 stroke stator, 2 stroke rectifer, and keep the wiring the way it is in the 2 stroke the same just cut/add whatever length you need. That should be all there is to it.
Post by Enviromoto on Sept 28, 2009 22:54:55 GMT -5
Ok well the lights are run off of the stator and thats whats throwing me a little. I know its just a matter of figuring out how much wattage is coming from the 2 stroke regulator but this scooter has had some electrical gremlins upon itself. I dont know its just feeling like a winter project. Besides I would really like to get the drag scooter done before it gets much cooler.
Post by 90GTVert on Sept 28, 2009 23:02:14 GMT -5
I understand, not saying you should rush. Just seeing what was up with it.
Post by Enviromoto on Oct 2, 2009 11:06:23 GMT -5
Brent what is the inside diameter of your 12mm 2 stroke crank? The part where the roller bearing and wrist pin sits.
Post by 90GTVert on Oct 2, 2009 13:27:43 GMT -5
Roughly 15mm.
Post by Enviromoto on Oct 2, 2009 15:18:30 GMT -5
Not 17mm?
Post by 90GTVert on Oct 2, 2009 16:28:09 GMT -5
On second look, maybe 15.5-16mm. Sorry, my mic has a dead battery. I've got a 10 and 12mm wrist pin lying around. I'll go measure them.
Post by 90GTVert on Oct 2, 2009 16:38:32 GMT -5
O.D. of the 12mm is about 16mm. O.D. of the 10mm is maybe 13.5mm. I checked and my stroker crank that is supposed to be for 12mm wrist pin won't fit a 12mm wrist pin. A 10mm wirst pin is very loose. Nice.
Post by Enviromoto on Oct 2, 2009 19:58:43 GMT -5
The OD of these 12/10mm reduction bearings is 17mm
Post by 90GTVert on Oct 2, 2009 20:38:03 GMT -5
I checked a service manual, but apparently it's fot 10mm pins. It says the small end service limit is 14.40mm. Looking around a little online I saw mention of the conrod being 17mm ID.
Post by Enviromoto on Oct 2, 2009 20:54:10 GMT -5
Ok good these should work then. I was a little worried.
Post by 2strokd on Oct 5, 2009 5:12:33 GMT -5
Im sure you know already, but keep in mind the bearing might feel loose until the pin is in it.
Post by Reign on Oct 11, 2009 12:14:09 GMT -5
So i just tried installing one of these 12/10 bearings with the 17mm OD, and they dont fit. I used my analog mic and the crank is 16mm, not 17mm. What sucks is that how I have the engine torn down, and can't rebuild it without either a new bearing, or a new piston and wrist pin.
