Post by Lucass2T on Sept 7, 2016 5:20:51 GMT -5
Bolting up ane exhaust goes in steps. First 'hang' it on the engine with all the bolts only 2 turns in. Use copper paste on the header studs.
Then support the exhaust with yoir hand and loosly tighten the flange (loosly:in a way you can loosen up the bolts with your fingers). Make sure theres no tension from the weight of the pipe on the flange when screwing in the header bolts.
Do the same with the engine mount. Make sure theres no tension on the pipe since it will tear open when it gets hot. Then tighten the flange and finally the engine mount.
Thats how I do it.
Post by tsimi on Sept 7, 2016 5:45:27 GMT -5
Thanks guys. I know how to mount a pipe that is not really an issue. My issue is that tension that Lucas just mentioned. I am currently measuring the pipe and then I will take a video which will explain it better. So stay tuned...
Post by tsimi on Sept 7, 2016 6:47:02 GMT -5
Ok got the pipe mounted! I extended the hole on the front mount of the pipe by 4-5mm and slightly bend the welded mount bracket out by maybe 2-3mm to take of that tension. Now all seems to be good. Thank you all for the help. Just painted the mounting bracket black and need to wait for it to dry before I can mount the pipe on my blue Jog.
Post by tsimi on Sept 7, 2016 7:32:36 GMT -5
So I just measured the pipe and before I started my Photoshop I quickly checked the pipe build thread and saw niz76 posted dimensions for a Next-R 100cc. I compared my data with his and I have the exact the same dimensions for my 50cc pipe. So creating another image with data on it is not necessary. A bit weird isn't it? A 100cc pipe has the same dimensions as a 50cc pipe. That is not good isn't it? 90GTVert Brent you can change the description/title in this post here to 50cc/100cc Next-R 49ccscoot.proboards.com/post/171014/thread
Post by 'O'Verse on Sept 7, 2016 7:57:15 GMT -5
I was looking threw some "next-r 70cc" on line and the stinger on the 70cc use to be skinnier. Maybe they changed to the new fatter stinger for heat purposes. Who knows. But there were actual 70cc only next-r's.
Post by tsimi on Sept 7, 2016 8:28:09 GMT -5
I heard of a Tecnigas RS 70, you and niz76 have a 100cc Next-R I got one that says for 50cc on it even though the dimensions are exact the same as for the 100cc. Some guys had a restrictor in it some not. Maybe the 50cc Next-R has baffles inside the 100cc doesn't? There seems to be no basic guideline with those Tecnigas pipes, kinda chaotic. I am very much looking forward to mount and drive the pipe. Hopefully I will be able to do that tomorrow or latest over the weekend.
Post by spaz12 on Sept 7, 2016 12:29:41 GMT -5
Post by tsimi on Sept 7, 2016 21:29:24 GMT -5
Went to the used bike parts store and found a set of aluminum wheels! Same as the white ones that I got but in black. So now I can put the white ones on my blue Jog and these new, black ones on my red Jog. No need to paint anything anymore.
Post by spaz12 on Sept 7, 2016 21:35:33 GMT -5
You come up on some great stuff.
Post by tsimi on Sept 7, 2016 22:01:46 GMT -5
You come up on some great stuff. Yeah, sometimes I get lucky and find such things. They also had the white ones but they were expensive since they are rare.
Post by spaz12 on Sept 7, 2016 22:07:20 GMT -5
You come up on some great stuff. Yeah, sometimes I get lucky and find such things. They also had the white ones but they were expensive since they are rare. You had to pay for them?
Post by tsimi on Sept 7, 2016 22:14:24 GMT -5
Yep, this time I paid for them $70. Can't get THAT lucky all the time.
Post by spaz12 on Sept 7, 2016 22:20:59 GMT -5
Oh, well 70 dollars is a good price. When ya gonna put em on and show the world?
Post by nelson on Sept 7, 2016 22:21:49 GMT -5
You come up on some great stuff. Yeah, sometimes I get lucky and find such things. They also had the white ones but they were expensive since they are rare. Man, i didnt even know aluminum rims available for the jog! I think yours are jog r but if it runs the minarelli i assume 10 inch rim? LUCKY! What did you pay if you dont mind my asking and how much are the white ones? Have you seen them for sale online any place? Sorry for all the questions, great find im excited for you! I see$70, was that for the set?
Post by tsimi on Sept 7, 2016 22:48:32 GMT -5
spaz12Don't know yet but asap, I hope. nelsonYes, 10 inch. You find the white ones for maybe $100 the pair and around $70 for the pair in black. They are from the Jog ZR and the white ones from the Jog ZR Evolution. At least I think they are aluminum that what I have been told. They do feel lighter then the stock 3 spoke. On page 76 I think I posted pics of the white ones.
