Post by 06jog on Dec 16, 2016 5:44:04 GMT -5
You probably won't be able to use those carbon reeds. If I'm not mistaken your Jog should have the angeled reed block which has larger reeds.
There are different ways to install the BBK. One method would be to remove the entire engine which means you
remove the rear shock,
unhook or remove rear brake cable,
remove the carburetor from the intake,
drain the oil tank empty to remove the oil hose,
remove the pipe/exhaust,
remove spark plug cable,
remove CVT cover if you have that clutch lock thing,
remove the mounting bolt.
Careful when removing the mounting bolt! The frame drops! So you better tight the scooter with some hooks or rope or whatever you have to prevent the scooter from dropping down or tip over to the side.
The other way would be to install it with the engine mounted which makes things really difficult do to lack of space around the Jog engine.
Not sure if you have seen the pictures of my install.
Check page 3
49ccscoot.proboards.com/thread/12255/jog-cv50r-70cc-polini-install
Also check out Brents tutorial. A lot good info there too.
49ccscoot.proboards.com/thread/556
Did you buy a BR8HS spark plug?
Hi
thanks for that. I am guessing you need to disconnect the throttle cable from the carb also.
i have not bought any spark plugs. I was going to buy 4 for tuning when I reject the carb. Are they the same as the original model or are they different to suit the new head.
