Post by joshua864 on May 4, 2015 12:54:02 GMT -5
Finally got my wider rear rim painted and put on with the stock size tire I plenty of clearance
Post by joshua864 on May 5, 2015 14:36:15 GMT -5
More scoot mail this should be it for a while lol after this I have my cvt completely tuned
Post by joshua864 on May 6, 2015 13:46:20 GMT -5
So I'm having a lil issue now I've installed the conta spring last week and my top end speed slowed down about 5mph thought it may have been from having the stock rollers so I got a new variator and 6g rollers now it's seems as if it won't go into final gear? I'm stuck now and don't know where to go next
Post by 90GTVert on May 6, 2015 13:56:41 GMT -5
Stiff contra springs can do that. Sometimes heavier rollers/sliders fix it and sometimes they don't.
Post by joshua864 on May 6, 2015 15:22:02 GMT -5
Well that sucks but I do have some 8g the thing that gets me is it was running fine till yesterday. it was shifting so to speak and was running fine and all of a sudden it went to sh!t.
Post by joshua864 on May 6, 2015 19:38:40 GMT -5
What would cause it the shake real bad when goes to wanna shift into final drive?
Post by joshua864 on May 7, 2015 12:45:08 GMT -5
Would it be better to go back to stock spring or try the 8g rollers?
Post by 90GTVert on May 8, 2015 8:00:09 GMT -5
If the stock contra spring worked without vibration and lack of speed you can go that route. You may want to see if there's coil bind with the aftermarket spring (coils are touching when the pulley compresses the spring.
Post by joshua864 on May 8, 2015 10:29:12 GMT -5
If the stock contra spring worked without vibration and lack of speed you can go that route. You may want to see if there's coil bind with the aftermarket spring (coils are touching when the pulley compresses the spring. There wasn't any binding and I had great acceleration but lacked top speed and revs seemed a bit high
Post by joshua864 on May 11, 2015 19:57:14 GMT -5
Just an update I went back to the stock vari and both 1500 springs with the 6g rollers. Haven't got to test it really since I'm pretty sure there's something broke in my clutch hopefully get to look at it tomorrow.
Post by joshua864 on Sept 25, 2015 15:39:47 GMT -5
Stretch fatty project is underway
Post by joshua864 on Sept 28, 2015 16:58:03 GMT -5
Post by joshua864 on Sept 30, 2015 22:31:25 GMT -5
Post by iwiketuddlz on Oct 1, 2015 4:22:04 GMT -5
I'm usually against the stretch look but man I Gota say yours looks sweet!!! Nice work Im dig in the rear wheel !!! Source?? I see you moved your tag back as well
Post by katastroff on Oct 1, 2015 6:54:34 GMT -5
That rear wheel is sweet!!!
