Post by joshua864 on Dec 17, 2015 21:20:42 GMT -5
Had to use 2 base gaskets the one that came with the taida kit and a hoca one, the hoca was slightly thicker but worked out almost perfect I think. This lil QMBEAST is a peppy lil thing. Haven't opened it up all the way yet but at around half throttle I'm cruising at about 40mph and it gets there FAST
Post by joshua864 on Dec 21, 2015 20:23:06 GMT -5
Well after only 28 miles on the build I had an issue today snapped the timing chain hoping I didn't mess anything up to bad such as valves hitting piston or screwed up any teeth on the crank. When I put this together I knew it was a tight fit. Do they make longer timing chains for stroker cranks? If so could I plz get some links
Post by 90GTVert on Dec 23, 2015 10:09:15 GMT -5
There are longer chains for stroker 150s, but I don't recall seeing them for 50s. Taida makes them for 150s, so you could try inquiring about a 50 chain where you bought your parts.
Post by joshua864 on Jan 13, 2016 0:29:09 GMT -5
Finally got around to making a longer timing chain added 2 links to it (hope that works) sonit went from 41 links to 43 links, the only thing I could find was a 45link but that wouldvr been too long
Post by joshua864 on Jan 13, 2016 0:34:28 GMT -5
Post by joshua864 on Jan 13, 2016 0:35:39 GMT -5
Still lots more painting to go but trying to take my time
Post by Fox on Jan 13, 2016 0:46:49 GMT -5
Nice work. Lot of time painting a scooter. On that chain, how did you split and replace the links exactly? The nail and the pop rivet have me wondering...I have never had to do that and I was thinking about a way you can thread it into the engine and then connect the chain so you don't have to pull the cases apart
Post by joshua864 on Jan 13, 2016 0:55:31 GMT -5
Nice work. Lot of time painting a scooter. On that chain, how did you split and replace the links exactly? The nail and the pop rivet have me wondering...I have never had to do that and I was thinking about a way you can thread it into the engine and then connect the chain so you don't have to pull the cases apart patience lots of patience I used a bicycle chain break to get it started but was to big to push it all the way out so once I got it flush I layed it on a 2x4 with a nail hole under the pin and used a punch to knock it the rest of the way out getting it back together was the hard part but about an hr fighting that tiny pin and lining it up some needle nose pliers, a vice, and a hammer and quite a few explicit words. Now I coulda spent $60 and ordered the one they sell on partsforscooters and saved some time but I really didn't have it to spend after Christmas and all
Post by joshua864 on Jan 13, 2016 18:23:55 GMT -5
Post by 90GTVert on Jan 13, 2016 22:38:50 GMT -5
Ouch. Seems like those are worth a shot. Other option would be contact a Taida dealer about replacements.
Post by joshua864 on Jan 13, 2016 22:53:11 GMT -5
Ouch. Seems like those are worth a shot. Other option would be contact a Taida dealer about replacements. i can get taida replacement but the wait is forever took about 2 months to get my parts to begin with
Post by joshua864 on Mar 20, 2016 20:36:18 GMT -5
Post by spaz12 on Mar 20, 2016 20:41:25 GMT -5
That looks like a LOT of work. It came out really cool looking through.
Post by niz76 on Mar 20, 2016 21:01:46 GMT -5
Those puzzle pieces look awesome! Plus with a nice meaning behind them too... Very nice!
Post by joshua864 on Mar 20, 2016 21:20:15 GMT -5
Yes it was very time consuming took about 3 days in all took 2 hrs just in taping up one side panel and cutting out puzzle pieces and had to do it 3x so yeah it's not perfect but looks good on camera and from a distance lol but I'm happy with it for now
