Post by 90GTVert on Jul 3, 2015 21:15:17 GMT -5
You can do the same thing basically to remove the bearings. Flipping the bolt/washers around. Or just drive them out if you don't care about the bearings. Slide hammer style puller would work. Heating the cases may ease the process.
Post by thatcrazyguy on Jul 3, 2015 21:23:29 GMT -5
You can do the same thing basically to remove the bearings. Flipping the bolt/washers around. Or just drive them out if you don't care about the bearings. Slide hammer style puller would work. Heating the cases may ease the process. Handheld torch work good? I don't care about the bearings, it's the bushings I have to be easy with and make sure I don't break because I can't wait more time to order, the anticipation is eating me alive here!! I wanted to ride today but Monday I'll get her done and installed! Will the nut bolt and washers method work for the bushings?
Post by 90GTVert on Jul 3, 2015 21:34:04 GMT -5
Heat gun or propane torch will work. I usually look for 250-300F. The bearings will heat up, but the aluminum should expand more quickly. They can be driven out without the heat, but it takes less force with heat.
Post by Sitticuss on Jul 4, 2015 5:22:02 GMT -5
I actually packed the variator with plastic explosives shaped like rollers.... Or they might be spares....
Post by thatcrazyguy on Jul 4, 2015 6:58:18 GMT -5
I actually packed the variator with plastic explosives shaped like rollers.... Or they might be spares.... hahaha ok ty
Post by thatcrazyguy on Jul 4, 2015 9:08:14 GMT -5
So I measured the slot on the engine cases that hold the mount bearings/bushings. I'm going to get a nut& bolt with approximately a 49mm and 26mm washer to pull those bearings out! Will do this Monday and I also have to pick up some of that motoseal grey sealant for the intake as I have to remove that to fit the subframe: Does anyone know if there is an aftermarket subframe that is longer?? Would love a nice stretch
Post by thatcrazyguy on Jul 4, 2015 11:33:18 GMT -5
I actually packed the variator with plastic explosives shaped like rollers.... Or they might be spares.... Hey do you know what size stroke this has? Or how I can find out
Post by Sitticuss on Jul 4, 2015 13:05:18 GMT -5
I actually packed the variator with plastic explosives shaped like rollers....::warning:: Or they might be spares....::popcorn:: Hey do you know what size stroke this has? Or how I can find out 45mm stroke 54mm bore
Post by thatcrazyguy on Jul 4, 2015 13:43:35 GMT -5
Hey do you know what size stroke this has? Or how I can find out 45mm stroke 54mm bore That's what I guessed so 103cc!!! Wonder where I can take this engine do you know your max speed? I don't have data left this month lmfao so no gps verified on phone
Post by thatcrazyguy on Jul 4, 2015 19:54:05 GMT -5
Is there any stretched sub frames or someway to fabricate mine to extend the engine back a bit?? Saw the kiesler kits but those looks so flemsy
Post by Sitticuss on Jul 4, 2015 22:42:23 GMT -5
That's what I guessed so 103cc!!! Wonder where I can take this engine do you know your max speed? I don't have data left this month lmfao so no gps verified on phone I think the fastest on that motor was 58mph. That was fast enough for me with 10" tires. My wifes scooter also had a high center of gravity. I'm sure there is more to be had there....
Post by oldgeek on Jul 4, 2015 23:00:44 GMT -5
Is there any stretched sub frames or someway to fabricate mine to extend the engine back a bit?? Saw the kiesler kits but those looks so flemsy The engine mount on my zip is a PITA. I think you would do best leaving it as is. One way to get a stretch on that scoot would to use a longcase mina, then you could move up to 12" tires
Post by thatcrazyguy on Jul 5, 2015 6:45:41 GMT -5
Is there any stretched sub frames or someway to fabricate mine to extend the engine back a bit?? Saw the kiesler kits but those looks so flemsy The engine mount on my zip is a PITA. I think you would do best leaving it as is. One way to get a stretch on that scoot would to use a longcase mina, then you could move up to 12" tires The zip r3i turbocams come stock with low profile 12" tires but I have my 10s onhere6
Post by thatcrazyguy on Jul 5, 2015 6:46:36 GMT -5
That's what I guessed so 103cc!!! Wonder where I can take this engine do you know your max speed? I don't have data left this month lmfao so no gps verified on phone I think the fastest on that motor was 58mph. That was fast enough for me with 10" tires. My wifes scooter also had a high center of gravity. I'm sure there is more to be had there.... Not too bad! I'll see what I can do and 50+ would be great cruising speed for me
Post by oldgeek on Jul 5, 2015 8:45:16 GMT -5
The engine mount on my zip is a PITA. I think you would do best leaving it as is. One way to get a stretch on that scoot would to use a longcase mina, then you could move up to 12" tires The zip r3i turbocams come stock with low profile 12" tires but I have my 10s onhere6 Thats right, I forgot LoL! It would still be cool to get something like a 130/70 12 on the rear.
