Post by thatcrazyguy on Jul 5, 2015 8:49:07 GMT -5
The zip r3i turbocams come stock with low profile 12" tires but I have my 10s onhere6 Thats right, I forgot LoL! It would still be cool to get something like a 130/70 12 on the rear. Hell yeah I'd love to get that tire on here!!! I don't even think it'll fit deflated lmfao! I wonder if low profile 13" rims will fit a short case?
Post by thatcrazyguy on Jul 5, 2015 22:33:11 GMT -5
Picked up some hardware to remove and install bushings and some more gasket sealant tonight. Tomorrow I will do the work and install and see how she rides!!! Still need to upgrade from 14mm carb to a 19-21. Got one in mind from a member here!
Post by Sitticuss on Jul 5, 2015 23:37:24 GMT -5
Picked up some hardware to remove and install bushings and some more gasket sealant tonight. Tomorrow I will do the work and install and see how she rides!!! Still need to upgrade from 14mm carb to a 19-21. Got one in mind from a member here! I wish I'd stuck with the 19mm. I did get it tuned with the 21mm though. You can fit a 12" rim with low profile tire. Might be a little wider and more stable.
Post by thatcrazyguy on Jul 6, 2015 6:09:58 GMT -5
Picked up some hardware to remove and install bushings and some more gasket sealant tonight. Tomorrow I will do the work and install and see how she rides!!! Still need to upgrade from 14mm carb to a 19-21. Got one in mind from a member here! I wish I'd stuck with the 19mm. I did get it tuned with the 21mm though. You can fit a 12" rim with low profile tire. Might be a little wider and more stable. I wish I can find a cheap one ivegot a killer deal for a carb n jets right now so I guess I can't pass it up
Post by thatcrazyguy on Jul 6, 2015 18:57:54 GMT -5
Got the bearings out of the 90cc engine motor mounts and have ordered the motor mount bushings I need. Within a week they shall be at the store for me to pick up. Didn't want to pay shipping and my wife can pick them up on her way home from work
Post by thatcrazyguy on Jul 6, 2015 19:58:56 GMT -5
Ok so I got the link to the video Brent had to install bearings. Is there any video that shows how to install rubber bushings? I imagine it's a whole different ball park
Post by spaz12 on Jul 6, 2015 20:01:40 GMT -5
Try the hot/cold method. If that doesn't work then you might have to press them in.
Post by thatcrazyguy on Jul 6, 2015 20:24:50 GMT -5
Try the hot/cold method. If that doesn't work then you might have to press them in. Hot/cold method will work for rubber? The heat won't melt the rubber?
Post by spaz12 on Jul 6, 2015 20:42:17 GMT -5
You heat the case and freeze the bushing
Post by thatcrazyguy on Jul 6, 2015 21:09:19 GMT -5
You heat the case and freeze the bushing Ok cool!!! Do I have to use a heat gun or will a propane torch be ok for a short amount of time?
Post by oldgeek on Jul 6, 2015 21:24:23 GMT -5
Ok so I got the link to the video Brent had to install bearings. Is there any video that shows how to install rubber bushings? I imagine it's a whole different ball park The same technique can also be used for bushings. Threaded rod, nuts, and appropriately sized washers or sockets. You have to find something that fits the outer ring of the bushing.
Post by thatcrazyguy on Jul 6, 2015 21:36:13 GMT -5
Ok so I got the link to the video Brent had to install bearings. Is there any video that shows how to install rubber bushings? I imagine it's a whole different ball park The same technique can also be used for bushings. Threaded rod, nuts, and appropriately sized washers or sockets. You have to find something that fits the outer ring of the bushing. I bought those the other day, should I freeze the bushing and heat the case? Or will just freeze the bushing to shrink it and use the bolt n washers?
Post by oldgeek on Jul 6, 2015 21:42:18 GMT -5
I just oiled mine and pulled them in, no hot or cold. Take is easy on the mounts if you heat them much, as they can easily crack if you apply pressure incorrectly, or pound on them trying to get the bushings in.
Post by thatcrazyguy on Jul 6, 2015 21:57:03 GMT -5
I just oiled mine and pulled them in, no hot or cold. Take is easy on the mounts if you heat them much, as they can easily crack if you apply pressure incorrectly, or pound on them trying to get the bushings in. Ok thanks bud.
Post by thatcrazyguy on Jul 8, 2015 8:07:19 GMT -5
Called the power sports company yesterday and they said there's a good chance the part will be in on Friday!! He'll give me a call when it arrives. Hoping it comes Friday and installed Friday and scootin to work on Saturday. Still have to break the motor in, best procedure for this?
