Post by mauibird on Jan 28, 2016 22:19:52 GMT -5
Post by mauibird on Jan 28, 2016 22:36:13 GMT -5
By the way, My Scooter Guru is going to give me a Jog expansion pipe (that has a really large down pipe) and a Dio Pg long pipe for a Franken Pipe build. The Pg longs for the Dio's are the best pipe ever! It handles all kinds of cylinders from 72 to 120cc with a broad rpm range. I can't wait to see how it handles on the Jog cylinder. Here's a couple of pics of my Dio PG Long…
Post by mauibird on Feb 19, 2016 22:45:09 GMT -5
Got the engine back from my Scootetr Guru. He did the works on it! He's awesome. Who makes the best crank bearing seals?
Post by mauibird on Feb 19, 2016 22:49:58 GMT -5
What I was most stoked on was my exhaust. He decided to put it together for me, and match it to my cylinder and case. Only Dio/Jog PG long out there! CHEEEEEHOOO!!
Post by mauibird on Feb 19, 2016 22:51:37 GMT -5
Here's a pic of it. I think I'll media blast it then clear coat it with VHT Flameproof paint.
Post by mauibird on Feb 19, 2016 22:57:23 GMT -5
He put new packing on the inside of the exhaust and everything. The packing was only at the last 6 inches of the pipe, and the screen left less than an eighth inch of room between the outer wall and the screen.
Post by oldgeek on Feb 19, 2016 23:14:20 GMT -5
This is gonna be good!
Post by mauibird on Feb 20, 2016 18:14:36 GMT -5
Anybody know what this small hole is underneath the transmission? It goes through where the bearings are, that hold the final drive shaft. Should I plug that with jb weld or what?
Post by moofus02 on Feb 20, 2016 18:19:59 GMT -5
Probably the vent hole
Post by Raizer on Feb 20, 2016 21:19:32 GMT -5
On my Suzuki it's between the seal and the bearing, if oil comes out there your seal is leaking.
Post by mauibird on Feb 20, 2016 22:14:44 GMT -5
Post by mauibird on Feb 22, 2016 3:30:31 GMT -5
Correction. i can weld 18 gauge. Its on. Bought some 18 gauge mild flat steel on flea bay, and a 10 lb spool adapter fort my welder. and wait…
Post by Lucass2T on Feb 22, 2016 3:55:41 GMT -5
Anybody know what this small hole is underneath the transmission? It goes through where the bearings are, that hold the final drive shaft. Should I plug that with jb weld or what? When a seal from the transmission will leak you'll see oil dripping trough that hole.
Post by mauibird on Mar 1, 2016 2:30:38 GMT -5
Post by Lucass2T on Mar 1, 2016 12:46:50 GMT -5
I keep looking at that headpipe. Where did your pipe guru got it from because it looks exactly like one off a Kundo F1...which are already quie rare over here let alone over there. Or is it from a Yasuni c20?
