Post by mauibird on Mar 19, 2016 23:49:16 GMT -5
I've never seen a Malossi delta clutch in person- but is that an adjustment to stretch the springs? Yup. you can adjust it to with in a few hundred rpm. There are weights underneath too. They have three holes witch can further adjust the hook up rpm, but most of all they affect how hard/fast the clutch pads hook up.
Post by mauibird on Mar 21, 2016 23:30:31 GMT -5
Wet sanded and used mothers aluminum polish on my cvt cover and the outer lip of my wheel.
Post by mauibird on Mar 21, 2016 23:31:52 GMT -5
Stage6 Extra soft spring on the way.
Post by ryan_ott on Mar 22, 2016 9:17:50 GMT -5
That cover came out good
Post by mauibird on Mar 26, 2016 18:07:46 GMT -5
I've been painting my body panel one day a week, for the last 2 months. Multiple coats of Krylon Fusion black satin and Fusion Clear. with wet sanding in between. Finally no dust specs!! I'll probably wetsand it one final time with 2000 grit. After that I'll polish it with Klasse, an acrylic protector.
Post by mauibird on Mar 26, 2016 18:10:19 GMT -5
Painted my fan too.
Post by mauibird on Mar 26, 2016 18:13:55 GMT -5
Post by mauibird on Mar 26, 2016 21:27:06 GMT -5
Malossi Shoes installed. It was harder working with these springs than the clutch springs! And, it doesn't fit. It's the right size but my wheel won't fit over the shoes.
Post by mauibird on Mar 26, 2016 21:28:55 GMT -5
Post by mauibird on Mar 26, 2016 21:30:17 GMT -5
So I ground down the shoe underneath the pivot point plates, and they fit fine.
Post by mauibird on Mar 26, 2016 21:33:15 GMT -5
Post by mauibird on Mar 26, 2016 21:53:01 GMT -5
Extra soft pink stage6 over range torque spring, yellow Malossi delta clutch springs, cnc bell
Post by mauibird on Mar 27, 2016 2:36:29 GMT -5
Painted cylinder and head with a krylon bbq paint to help with cooling
Post by mauibird on Mar 27, 2016 3:06:59 GMT -5
Post by oldgeek on Mar 27, 2016 5:55:03 GMT -5
looking nice!
