Post by mauibird on Apr 23, 2016 22:27:09 GMT -5
My version of Brents brake bracket
Post by mauibird on Apr 24, 2016 1:29:22 GMT -5
Trimmed it up a little more and painted.
Post by mauibird on May 13, 2016 2:59:45 GMT -5
Got some stuff done today…Tire mounted. P rating for 93mph
Post by mauibird on May 13, 2016 3:02:24 GMT -5
Post by mauibird on May 13, 2016 3:05:03 GMT -5
Post by mauibird on May 13, 2016 3:07:42 GMT -5
Rear brake line installed on home made bracket.
Post by mauibird on May 13, 2016 3:10:18 GMT -5
Just enough clearance on the spark plug boot.
Post by mauibird on May 13, 2016 3:12:29 GMT -5
Im reaaaally curious how that pipe's gonna perform! ...it looks soo damn short...even for a high-end 70cc pipe. They work great on the Dio's. Granted the Dio is a vertical cylinder and the header is longer… I was curious about the same thing, and I measured it, and my Kundo/PG Long is an inch longer than my V8 pipe. FINGERS CROSSED. The pipe looks bigger with the engine to reference it by
Post by niz76 on May 13, 2016 7:53:13 GMT -5
Holy cow that pipe does look big! Haha. Looks like you're tackiling all the details! Lookin great!
Post by mauibird on May 15, 2016 2:11:20 GMT -5
Got some work done today. Hooked up a new black throttle cable and dialed it in. Stripped the clamping bolts on my quick throttle so retapped them to a 6mm bolt. Took a file to the inner parts of the throttle so it snaps back. Installed gas tank, rear fender,tail lights, and rear rack.
Post by mauibird on May 15, 2016 2:15:22 GMT -5
Post by mauibird on May 17, 2016 5:59:57 GMT -5
Post by oldgeek on May 17, 2016 6:23:50 GMT -5
Lookin good!
Post by mauibird on May 18, 2016 17:51:58 GMT -5
Got er tuned, for now. She pulls hard through mid throttle, and just keeps pulling at wide open. This is where I ended up with the tuning of my 90cc polaris block. 54mm aluminum autotech55 bore. 45mm full circle drr crank. 6.75:1 drr gears. 28mm oko, 55 pilot with the a/f screw 2 full turns to the left. 152 main jet with the needle on the top notch (leaning out mid throttle). Malossi Overrange transmission with 8 gram weights. Stage6 Pink extra soft torque spring, and yellow malossi clutch springs. I don't want to jinx it, but it is running great!! Thanks everyone for the advice. I'll get a video on my next day off, and do some top speed tests.Oh yeah, that Kundo/pg long is SICK!!!
Post by oldgeek on May 18, 2016 19:44:05 GMT -5
