Post by mauibird on Apr 29, 2015 19:58:47 GMT -5
Didn't want to hack this up.
Post by mauibird on May 8, 2015 18:45:34 GMT -5
Post by mauibird on May 9, 2015 6:46:28 GMT -5
this one little piece has been holding my build up. Well it's here and I'll see if it fits tomorrow.
Post by 90GTVert on May 9, 2015 7:10:36 GMT -5
That's how it usually works. You have a pile of parts and some $0.10-$10 item will prevent any progress.
Post by mauibird on May 9, 2015 18:12:17 GMT -5
Tapped it on slowly with a small socket wrench and a hammer. I'll see if I can put it together on monday. I'm gonna use just bearings and no cage.
Post by mauibird on May 12, 2015 1:18:51 GMT -5
Got some work done today. Mounted the Metro tree and dio disc brake set up. The 200mm rotor wouldn't work. The caliper was to big to fit inside the rim Luckily my Scooter Guru had a 160mm rotor that worked perfect with the stock Dio caliper adapter. It doesn't look as cool but it will get me going. Rotor lined up perfectly with the top of the pads(in blue)
Post by mauibird on May 12, 2015 1:24:50 GMT -5
Post by mauibird on May 12, 2015 1:30:31 GMT -5
I work a bunch of doubles this week. Hopefully I'll be able to work on it this week end.
Post by oldgeek on May 12, 2015 5:24:08 GMT -5
I work a bunch of doubles this week. Hopefully I'll be able to work on it this week end. The scoot is looking good! I cant wait to hear about that aluminum BBK you have there!
Post by 2TDave on May 12, 2015 6:09:48 GMT -5
Looking good! Dropping the bars is on the list for my Venus 103cc.
Post by 90GTVert on May 12, 2015 7:17:35 GMT -5
Very nice. That bar setup looks great on there.
Post by mauibird on May 13, 2015 2:59:22 GMT -5
I pulled the bike out today and noticed a scraping sound. I thought it was the rotor on the pads, but upon further inspection, I noticed this The brake pad was scraping on the hub of the rim. WTH!
Post by mauibird on May 13, 2015 3:07:44 GMT -5
I bought Honda Dio front rim, Dio caliper, Dio forks, and used stock size rotor from a SYM DD50 ( which is the same as a Honda Dio). So of course they don't fit right. So, I ground down the metal part of the pad, right up to the pad, and it made clearance, by like 1mm. I'll have to pay attention to it when I ride, after it heats up. Down the road I'll try a larger rotor, with adapter, for better clearance. This should work for now, I might have to grind down the other pad too. I'll see after I get the brake system filled and bled.
Post by mauibird on May 13, 2015 3:09:55 GMT -5
Barely clears the hub.
Post by mauibird on May 13, 2015 3:11:03 GMT -5
I wonder If I can get shorter pads?
