Post by encephalon on Jun 25, 2015 17:33:05 GMT -5
I wanted to see if i would benefit from any modifications to the variator for more belt travel. This is what I found: That seems like it's pretty much all she's got doesn't it? Not sure if I feel comfortable filing down the drive faces for more. I was comparing this to others I've seen on the forum. Then I thought about the over range variator mod. I found this: This is the stock variator. Doesn't seem like I can do anything there either. What are yall's thoughts on this?
Post by 90GTVert on Jun 26, 2015 8:25:38 GMT -5
That's pretty much what mine is doing (belt travel). Seems pretty normal for a basically stock CVT. The OR mod was for the 2T Minarelli's CVT. Those posts won't actually make it go faster or travel more. It just lets it travel more with the ramp plate well supported so guides don't constantly break for that application.
Probably the easiest thing to do would be try and aftermarket variator. The Hoca is about $50, though they are 10% off this month at PFS . There's a DLH of Koso on eBay that can usually be had for $20-30. You can try heavier rollers, but mine hasn't seemed to gain travel beyond there with heavier sliders.
Post by encephalon on Jun 28, 2015 6:52:53 GMT -5
Cool, thanks man. I guess I'll just have to wait on that BBK. I saw this Vento Zip R3 on my local CL ads. augusta.craigslist.org/mcy/5085514323.htmlI kind of want to sell this tao tao and get that instead...just have to find someone who will buy the tao tao for 500 bucks...
Post by Kick start on Jun 28, 2015 10:24:26 GMT -5
you should get a performance variator and make it lighter then what it is so you can go faster
Post by thatcrazyguy on Jun 28, 2015 21:30:35 GMT -5
Cool, thanks man. I guess I'll just have to wait on that BBK. I saw this Vento Zip R3 on my local CL ads. augusta.craigslist.org/mcy/5085514323.htmlI kind of want to sell this tao tao and get that instead...just have to find someone who will buy the tao tao for 500 bucks... That is a great scoot at an amazing price!! I'd pick it up asap and sell the taotao later!
Post by thatcrazyguy on Jun 28, 2015 22:09:32 GMT -5
Is that in Augusta Maine
Post by encephalon on Jun 29, 2015 0:27:54 GMT -5
Yeah totally...if I could afford 500 bucks right now lol. It's Augusta, GA
Post by encephalon on Jul 11, 2015 21:47:23 GMT -5
I finally ordered my BBK tonight. Went with the 02starrider 50mm kit with BVH and a9 cam. I'm pretty excited. I also went ahead and bought a gates powerlink belt and a new variator fan cause the previous owner broke the kick start and shredded it. I'll keep you guys updated when it comes in.
Post by encephalon on Jul 15, 2015 17:30:02 GMT -5
Got some stuff in the mail today.
Post by encephalon on Jul 16, 2015 0:16:22 GMT -5
Finished installing the kit tonight. Pretty easy and straight forward. I'll have to do some port matching. The intake manifold and spacer are WAY off and it bugs the crap out of me. Also have to put some fresh oil in. It's late and my room mate is sleeping so I can't use the dremel. My muffler is really loud so I don't want to wake the neighbors. So that makes me have to wait until tomorrow for first start up. bollocks.
Post by Availien on Jul 16, 2015 0:25:18 GMT -5
Finished installing the kit tonight. Pretty easy and straight forward. I'll have to do some port matching. The intake manifold and spacer are WAY off and it bugs the crap out of me. Also have to put some fresh oil in. It's late and my room mate is sleeping so I can't use the dremel. My muffler is really loud so I don't want to wake the neighbors. So that makes me have to wait until tomorrow for first start up. bollocks. I have the same head. I also had the same skin crawling irritation from the port not matching the intake manifold and spacer gasket. My solution: www.ebay.com/itm/161718008271?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITwww.ebay.com/itm/130973140607?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITMatched the hole in the valve head almost perfect. Tried the dremel on the stock spacer gasket first and cracked it. The carburetor didn't fit in the manifold right. It's a little over sized. So I took the clamp off of the old manifold and used that instead. Worked perfect.
Post by encephalon on Jul 16, 2015 0:32:33 GMT -5
Very cool info man, thanks. Might as well go to a 150cc carb as well right??? JK.
Post by Availien on Jul 16, 2015 0:36:01 GMT -5
Very cool info man, thanks. Might as well go to a 150cc carb as well right??? JK. Actually, maybe so. Some people do and their bikes love it. It's a possibility that I am seriously considering.
Post by Kick start on Jul 16, 2015 12:19:13 GMT -5
Very cool info man, thanks. Might as well go to a 150cc carb as well right??? JK. I try the 150cc intake and 24mm 150c carb and the carb is to big for that size valve head. shots flames 7-8 inch out the pipe
Post by thatcrazyguy on Jul 16, 2015 12:26:31 GMT -5
Very cool info man, thanks. Might as well go to a 150cc carb as well right??? JK. I try the 150cc intake and 24mm 150c carb and the carb is to big for that size valve head. shots flames 7-8 inch out the pipe Looks like its a keeper
