Post by redneck on May 27, 2015 20:03:02 GMT -5
i was actually throwing around ideas of using a ruckus battery box but still not set on it
Post by redneck on May 27, 2015 20:09:08 GMT -5
any one use an ammo can as a battery box just toying ideas in my head for the build
Post by scooterpimp on May 27, 2015 20:16:58 GMT -5
Good idea! Used one on a old sporter back
in the day. Could hide battery , solenoid , keyswitch etc. In that bugger on a scoot!
Post by redneck on May 27, 2015 20:20:39 GMT -5
any on got any picture?
Post by redneck on May 27, 2015 20:24:27 GMT -5
hmmm mabey like this ?
Post by redneck on May 27, 2015 20:32:46 GMT -5
very close to what I wana build
Post by Elektrey on May 27, 2015 20:52:53 GMT -5
I've thought about putting a bar through the front part of my scooter like that, just for looks though, sort of like a "roll cage" style thing up in front.
Post by redneck on May 27, 2015 21:03:10 GMT -5
even just for looks it will help with keeping the frame more ridged ive noticed on several scooters u can feel the frame flex when going over bumps
Post by 90GTVert on May 27, 2015 21:05:46 GMT -5
Totally different feel on mine before and after the frame brace. Worth losing the step through for it.
Post by redneck on May 27, 2015 22:10:01 GMT -5
will a 130/90/R10 fit on this it has a 3.50-10 on the rear now that's bald im looking at some kenda dual sports just not sure what the tire chart conversion is
Post by Elektrey on May 27, 2015 22:24:50 GMT -5
My rim is 3.5x13 and I fit 130/60R13s so I would say that yes a 130mm wide tire would fit on a 3.5 inch wide rim.
thats pretty tall profile though, check to make sure the increased diameter will fit in the case and such
Post by redneck on May 27, 2015 22:29:25 GMT -5
that's the problem I have no idea what the diameter difference is going to be hmmmm
Post by redneck on May 27, 2015 22:30:29 GMT -5
or width
Post by Elektrey on May 27, 2015 23:00:34 GMT -5
quick google says 100/90-10 is similar size to a 3.5x10 tire.
so your current tire is somewhere around 90mm of tire sidewall and a 130/90 will have 117mm of sidewall.
about half an inch increase in radius
Post by 90GTVert on May 28, 2015 8:13:41 GMT -5
