Post by iwiketuddlz on Aug 3, 2015 19:09:49 GMT -5
Yes sir!!! Exactly how i did mine and it fired right up!!! Also im not sure what my timing is now because I have moved it a few times....I bet it really close to excaly TDC....also can you check the voltage from your white and yellow wire when Idling??? That would really help me as I'm having trouble with my iggy ATM..... The charging part....and your charge wire at the battery Thanks
Post by ryan_ott on Aug 3, 2015 21:56:45 GMT -5
Too late to run it too long but it runs!! It's frekin loud.
Post by iwiketuddlz on Aug 3, 2015 22:38:52 GMT -5
Whhooooo whooooo awesome bro!!!! Braaaap braaaaaaaap
Post by spaz12 on Aug 4, 2015 0:16:07 GMT -5
The sweet smell of success!
Post by Lucass2T on Aug 4, 2015 2:31:15 GMT -5
video video video video video
Post by 190mech on Aug 4, 2015 4:15:18 GMT -5
Dont know for sure,but isnt the arrow for the direction of rotation??
Post by ryan_ott on Aug 4, 2015 9:04:58 GMT -5
Dont know for sure,but isnt the arrow for the direction of rotation?? The arrow points either direction. I think the stator and plate are kind of universal, there are a few different mounting holes. I would think if I lined it up with the upper notch it wouldn't run as that's about 90 degrees off of the other. I'll look into it more before I ride it.,
Post by iwiketuddlz on Aug 4, 2015 10:08:08 GMT -5
You must have it pretty damn close or else it would not run!!! I adjusted mine while idling to th best idle then took it for a ride and that was it!!!! When you do check your AC voltage plz check before you plug up to the scoot harness basically the white/yellow wires straight out of stator while idle......Thanks man I do apriciate it.... I believe mine has went to the bad.....sucks
Post by ryan_ott on Aug 4, 2015 10:10:32 GMT -5
As requested here's is the pic of the front. Plenty of air flow. Poor quality dark video
Post by iwiketuddlz on Aug 4, 2015 10:15:41 GMT -5
Awesome man looks great!!!! I'm curious to what your temps will be!!!!!
Post by ryan_ott on Aug 4, 2015 10:19:35 GMT -5
I'll check the voltage when I get home.
Post by ryan_ott on Aug 4, 2015 16:55:13 GMT -5
I've got 6.5 vac to ground on each wire at idle, 12.5+ reving
Post by iwiketuddlz on Aug 4, 2015 17:47:49 GMT -5
Thanks for that info!!! Mine is readding the same!!! Glade I have someone/something to compare to!!!!!also can you check one other voltage for me?? The charging wire unhooked from the battery at idle?? What DC volts to you have?? Thanks again bro....
Post by ryan_ott on Aug 5, 2015 12:14:17 GMT -5
Here is a better vid if it running. I found that I need to clearance inside the CVT cover more as my rear pulley is rubbing. Once I get that done I'll take it for a spin.
Post by ryan_ott on Aug 5, 2015 12:56:39 GMT -5
