Post by lshigham on Mar 23, 2011 14:16:27 GMT -5
That's why it doesn't run out of gears til 75
Post by lshigham on Mar 24, 2011 16:34:30 GMT -5
Small update. The ported and flowed block has been delayed so I've decided to get the one I have back up and running, which requires the plugging of quite a few holes I reckon it's doable though - JB weld FTW I split the cases and removed the crank. The most time consuming thing was removing the flywheel, it was sort of welded on with bits of shredded woodruff key spread evenly between the two. Didn't get any pics as my hands were filthy. I'll get some when I go back out in a mo.
Post by Thebatman on Mar 24, 2011 18:10:20 GMT -5
wow, man that was nasty... I hate to see that.. sorry to hear about the delay...i'm sure it'll be running VERY soon......unlike mine :no: :rofl:
Post by 190mech on Mar 24, 2011 18:37:35 GMT -5
Wonder if that sheared key was the reason for the strange running lately... :stumped:
Post by lshigham on Mar 25, 2011 4:49:26 GMT -5
Wonder if that sheared key was the reason for the strange running lately... I don't think so, as the vari drive plate had also been sheared off.
Post by lshigham on Mar 25, 2011 18:28:05 GMT -5
Port mismatch, anyone? That's better Repairs Making sure the mating surface is true with wet and dry and the flat top of a saw.
Post by 90GTVert on Mar 25, 2011 18:59:39 GMT -5
Nice work. That thing sure has some stout oil passages.
Post by 190mech on Mar 25, 2011 20:35:43 GMT -5
That looks like a very well designed engine!Great work too!! :cheers:
Post by lshigham on Mar 26, 2011 5:48:37 GMT -5
:thumb: thanks guys.
Next on the agenda is to collect a crank and cylinder, should be a job for later today. It will be back on the road for Monday :scared:
Started painting the CVT cover whilst I waited for the exoxy to cure, I will post pics when it's done.
Post by 2strokd on Mar 26, 2011 11:14:18 GMT -5
Nice work. That thing sure has some stout oil passages. Sure does! Wonder if enlarging ours would be a bad idea?.. I have thought about it for some time now.
Post by lshigham on Mar 26, 2011 14:31:10 GMT -5
Been shopping ;D Here we have: -S6 racing cylinder -S6 CNC drive face -S6 intake manifold and reeds -SKF main bearing and seals set -STR8 CNC kickstart -Stock flywheel -Flywheel, vari and clutch nuts -Red anodised alu CVT bolts -£42 crank (which, according to Shiny, looks like a copy of the Malossi one)
Post by shakerdriver on Mar 26, 2011 16:27:48 GMT -5
I wish there was a store locally we could just run out to and pick parts off the shelf like you can Ishigham.
Post by lshigham on Mar 26, 2011 18:19:20 GMT -5
I wish there was a store locally we could just run out to and pick parts off the shelf like you can Ishigham. Wouldn't call it local, it's a 3hr round trip. Still, better than waiting til Tuesday for the parts. Almost done now, pics to follow
Post by 90GTVert on Mar 26, 2011 19:17:54 GMT -5
It would take us 3hrs just to get through airport security to get on the plane to head to somewhere that has that much stuff around. lol I couldn't afford the plane, let alone the parts once I arrived.
Post by lshigham on Mar 27, 2011 3:31:32 GMT -5
It would take us 3hrs just to get through airport security to get on the plane to head to somewhere that has that much stuff around. lol I couldn't afford the plane, let alone the parts once I arrived. I can drive across the country in 4-5hrs Mind you, it would cost me a fortune in fuel :rofl:
