Post by 90GTVert on Apr 23, 2011 10:37:41 GMT -5
:stars: My head is spinning just watching you buy all this stuff. :stars:
Post by lshigham on Apr 23, 2011 10:42:20 GMT -5
My head is spinning just watching you buy all this stuff. I can hear my wallet going ''no, no stop it!!!'' :rofl: :help:
Post by Reign on Apr 23, 2011 10:44:55 GMT -5
My head is spinning just watching you buy all this stuff. I can hear my wallet going ''no, no stop it!!!'' I know that feeling all too well! It was the same way when I forked over the money for my Yasuni pipe
Post by lshigham on Apr 23, 2011 17:00:19 GMT -5
The current plan is to fit the new S6 racing cylinder when it arrives, and use a known good setup with the Racing and R1200 (rollers, jetting, needle etc.) and send the old one back for replacement should it turn out that it is indeed defective. The replacement cylinder will then hopefully find itself going for a journey across Europe into the capable hands of Bram from Scooter Invasion, who will work his magic while I use the other S6 racing kit to get around. I'm then going to try and resist the urge to put the then spare kit on my other runner with the C16 and probably fail too :help:
Post by lshigham on Apr 25, 2011 15:27:38 GMT -5
Post by 90GTVert on Apr 25, 2011 15:30:19 GMT -5
Is that a totally stock rear pulley or is the TD aftermarket? Either way, it makes me jealous. lol
Post by lshigham on Apr 25, 2011 15:32:41 GMT -5
Totally stock, one of the few things that is
Post by 90GTVert on Apr 25, 2011 18:55:44 GMT -5
Dang. I already knew they had large pulleys, but you have more performance oriented straight groove torque drivers too.
Post by lshigham on Apr 26, 2011 10:46:57 GMT -5
''Dear Luke, We want to let you know that your order 5360/230411/34 status has been updated to... DISPATCHED'' :itshere: ^^^ tomorrow morning
Post by lshigham on Apr 27, 2011 3:42:21 GMT -5
Tis now tomorrow morning and I have a shiny new S6 cylinder in my hand. Even better - it has the correct port timings. Measured super accurately with a caliper and the piston Ex: 20.19 I did do the transfers and boost port, but the measurements were inconsistent by around 0.5mm each time I did them. It's hard to see when the port is properly open, as unlike the exhaust port you can't see daylight. The exhaust port measurement was within 0.05mm each time I did it, so I'm fairly sure it's accurate.
Post by lshigham on Apr 27, 2011 3:43:41 GMT -5
Oh and I got a load of stickers thrown in, even one I've been after for ages ''scooter tuning is not a crime'' ;D
Post by 90GTVert on Apr 27, 2011 6:25:32 GMT -5
:stars: :lol: I did do the transfers and boost port, but the measurements were inconsistent by around 0.5mm each time I did them. It's hard to see when the port is properly open, as unlike the exhaust port you can't see daylight. The exhaust port measurement was within 0.05mm each time I did it, so I'm fairly sure it's accurate. If you're measuring off the scoot, try shining a bright flashlight up through the boost/transfer ports.
Post by lshigham on Apr 27, 2011 10:09:00 GMT -5
Yeah, it was off the scoot. I'll bear that in mind in future, thanks. I did manage to get it all fitted, time for a proper test ride It moves, which is more than last time :lol: I've taken vids and pics, which will follow later.
Post by lshigham on Apr 28, 2011 3:33:45 GMT -5
Time for a mega update ;D Firstly, I will say that it works!!! :scoot2: Right, on with the pics. Starting point Stub fitted Test fitting for squish check. Note the lack of sealant and piston ring Perfect Gaskets fitted with a little grease to hold them in place Getting there Done Squish re-check Just needs an exhaust and coolant And this one's for those of you with tiny 14mm carbs to drool over And finally, a video of it's first test firing. Yes, I did go a bit OTT with the oil during assembly
Post by 190mech on Apr 28, 2011 4:32:31 GMT -5
Well done!Does it run better with the new cylinder?
