CHT?
Sept 19, 2015 6:47:15 GMT -5
Post by birdman on Sept 19, 2015 6:47:15 GMT -5
In the brake levers there is a switch called the brake light switch, when you pull the brakes in, the switch's contacts close completing the circuit and illuminating the light. That wiring diagram confuses me There should only be two wires coming from the battery. Also All of the black (-) wires could be attached to the frame to help simplify things. Also I would think pulling power (+) from the taillight circuit would allow the display to be turned on and off with the key. The headlight only turns on with the engine if I am not mistaken, so getting power from there would only turn on the display when the engine is running.. We can sort it out tomorrow if you like.
CHT?
Sept 19, 2015 7:02:52 GMT -5
via mobile
Post by tsimi on Sept 19, 2015 7:02:52 GMT -5
Thanks birdman That would be awesome! Looking forward to it.
I don't know where the brown wire goes but all three go somewhere inside the inner panel and i guess minus and plus go or come from the stator or battery?
CHT?
Sept 19, 2015 9:51:56 GMT -5
Post by Elektrey on Sept 19, 2015 9:51:56 GMT -5
www.cobrasales.com/docs/TGB-R50X-Wiring-Diagram-20091118.pdfheres my wiring diagram. As you can see the ON switch connects 3 and 4. 3 being the positive to the battery, so the 4 wire is the ignition ON hot lead. you can see what 4 connects to (brake switch, speedo/tach, CDI, oil sensor, 9V power source under the seat) Also I do not know if the gauge works or not, I assume so, but I haven't gotten my engine back together to run the stator to get it power.
Post by tsimi on Sept 20, 2015 9:02:32 GMT -5
birdman came over today and helped me with the wiring. He figured out the right wire. Now all is good!
CHT?
Sept 20, 2015 13:44:19 GMT -5
tsimi likes this
Post by spaz12 on Sept 20, 2015 13:44:19 GMT -5
I love how that tach looks! The way the needle spins up and then back up is pretty cool to. I know that most of them do it, but I'm easily impressed What's with the temp gauge numbers cycling on and off? Or is that the camera doing that?
Post by Deleted on Sept 20, 2015 14:02:40 GMT -5
My guess is it's the camera's FPS strobe effect doing that. (Like used to happen when filming a crt tv display)
Bill
CHT?
Sept 20, 2015 16:07:46 GMT -5
via mobile
spaz12 likes this
Post by tsimi on Sept 20, 2015 16:07:46 GMT -5
spaz12 As PirateLabs said its a camera thing. They don't cycle like that.
CHT?
Sept 20, 2015 16:15:30 GMT -5
Post by spaz12 on Sept 20, 2015 16:15:30 GMT -5
That's what I was thinking too.
Post by tsimi on Sept 20, 2015 16:16:58 GMT -5
The highlight of that day was birdman and me went for a drive with my two Jogs. That was an awesome feeling to drive with someone together. We went to the liquor store to get some beer and came back to play some Metal Gear Solid 5. spaz12 did you see my stock speedo meter? It does also that opening ceremony thing. That's stock Yamaha.
CHT?
Sept 20, 2015 16:20:06 GMT -5
tsimi likes this
Post by spaz12 on Sept 20, 2015 16:20:06 GMT -5
That's really the only way i like to ride; with my buddy. I get bored easily when I'm by myself.
CHT?
Sept 23, 2015 9:15:08 GMT -5
Post by tsimi on Sept 23, 2015 9:15:08 GMT -5
And on a side note; get some McGuires Back to Black for those plastic pieces on your dash and knee panel. The stuff is amazing at bringing that plastic back to life. Beside, you can't have that pretty red paint job and then those dull black panels. That just doesn't cut it man spaz12 PirateLabsLet's continue the conversation about the inner panels here.
CHT?
Feb 10, 2016 3:24:10 GMT -5
tsimi likes this
Post by Raizer on Feb 10, 2016 3:24:10 GMT -5
CHT?
Feb 10, 2016 7:05:12 GMT -5
via mobile
Raizer likes this
Post by tsimi on Feb 10, 2016 7:05:12 GMT -5
Looking forward to your review once you get it. If it is working good and also smaller then I might order one myself.
CHT?
Feb 10, 2016 7:19:35 GMT -5
Post by Raizer on Feb 10, 2016 7:19:35 GMT -5
Yeah I'm quite interested to see how it goes too! I was specifically after a smaller one as I've got a couple different ideas on ways to mount it that wouldn't have easily worked with a bigger one. Going to try weather prof the install too, I don't often plan on riding in the rain, but I keep getting caught in heavy downpours lately... and it's supposed to be summer! Ordered a custom length thermocouple from that Aliexpress link, 14mm angled ring with fork terminals to suit the display, US$7.20 with free shipping. Asked for 1.25meters to give a little extra length to give a bit of flexibility in mounting location and he kept saying 1.5m, so I may have to cable tie a coils of wire away somewhere under the plastics haha Also ordered a few other interesting items for my scooter today, but this isn't the thread for it
CHT?
Feb 10, 2016 14:36:42 GMT -5
via mobile
Post by Lucass2T on Feb 10, 2016 14:36:42 GMT -5
The highlight of that day was birdman and me went for a drive with my two Jogs. That was an awesome feeling to drive with someone together. We went to the liquor store to get some beer and came back to play some Metal Gear Solid 5. spaz12 did you see my stock speedo meter? It does also that opening ceremony thing. That's stock Yamaha. Sounds awesome!
