CHT?
Aug 21, 2016 18:37:50 GMT -5
Post by thunderific on Aug 21, 2016 18:37:50 GMT -5
Ok so i tryed and tryed every possible way to gett a more constant readout.. And it seems nothing did the trick.. Then i took the probe out of the 14mm spark plug ring housing and drilled a hole in a m8 alu bolt.. Put that probe in glued it with 400°c silicon.. Drilled a hole thru 2 cylinder fins and screew that bolt in.. I must say that its more than enough for me now.. Its reading temps almost the way it should. Not perfect butt good.. Quick question......do most 50cc scoots take the 10mm CHT sensor ? Is that about right or what? I need to start monitoring this baby's internals right away.
Post by tsimi on Aug 21, 2016 18:47:05 GMT -5
Don't take my word for it but I think 4strokes use a 10mm and most 2strokes use a 14mm.
CHT?
Aug 21, 2016 22:21:44 GMT -5
Post by thunderific on Aug 21, 2016 22:21:44 GMT -5
Don't take my word for it but I think 4strokes use a 10mm and most 2strokes use a 14mm. Thank you sir
CHT?
Aug 21, 2016 22:32:18 GMT -5
via mobile
Post by tsimi on Aug 21, 2016 22:32:18 GMT -5
To make 100% sure you best remove the spark plug once and measure the diameter of the threaded part of the spark plug.
Post by sobotek on Sept 1, 2016 2:11:20 GMT -5
Tsimi is right 2stroke use 14mm and 4poke uses 10mm
