Post by derbiman on Oct 24, 2015 20:57:46 GMT -5
Black looks good too!!!
Post by spaz12 on Oct 24, 2015 22:10:28 GMT -5
When I fix a cracked panel, I always take a dremel tool and run a round head rasp tool over the crack to gouge it out some. Then I apply fiberglass drywall tape to the back side with epoxy over the tape. On the finish side, I fill the crack with epoxy and sand it smooth. It keeps the panel from cracking again. Just my 2¢ I used that stuff that you find on the bottom of sofas and box springs because I can get it by the rolls for nothing, and with the plastic cement I'm hoping that it holds up. It seems pretty strong. Oh, and I did take a rasp to it as well. That's good advice, thank you
Post by spaz12 on Oct 24, 2015 22:17:17 GMT -5
I use a small bag that I zip tied to rear rack for a little storage. It will hold a bottle of oil and a couple tools etc etc. Here's a bad pic, but I'm sure you get the idea. I had not thought of that! Now I just have to go buy one of those damn expensive racks. Do you use the stock air box? That thing was a huge PITA to get on! I had to have help lol
Post by PIG on Oct 25, 2015 1:01:22 GMT -5
Ohh ya these things are bitch to work on. Any motor work, just pull the motor out and save yourself the headache. FYI put the plastic motor cover back on before you put the motor back on the scoot. For the air box, put the rubber adaptor on the carb then put the back half of the the air box on, then screw the cover on. Also leave the one cvt cover bolt that's closest to the fold out foot peg off. If you don't you have to remove that peg and some of the floor board bolts just to remove the cvt cover. There's a lot of little tricks that you'll figure out as you go.
Post by spaz12 on Oct 25, 2015 2:17:09 GMT -5
How about that piece under the dashboard... It needs to be painted because the fools got overspray all over it when they did their hack job of a paint job. I'm just masking off everything since I see no way of removing it unless I remove the handle bars, and that's just too damn much trouble. It's a pain in the butt, but it's a pretty cool little scoot. I can't wait to put that top end on it
Post by aeroxbud on Oct 25, 2015 17:12:26 GMT -5
Ohh ya these things are bitch to work on. Any motor work, just pull the motor out and save yourself the headache. FYI put the plastic motor cover back on before you put the motor back on the scoot. For the air box, put the rubber adaptor on the carb then put the back half of the the air box on, then screw the cover on. Also leave the one cvt cover bolt that's closest to the fold out foot peg off. If you don't you have to remove that peg and some of the floor board bolts just to remove the cvt cover. There's a lot of little tricks that you'll figure out as you go. On my BWS I used to leave the top left bolt out the case, otherwise you have to take the engine out, or remove the bodywork. A right pain when you wanted to change the rollers
Post by birdman on Oct 25, 2015 21:31:09 GMT -5
I always thought working on my vertical jog was easy compared to the horizontal jog. On the vert jog i just pulled bidy panels to accss the jug and carb workcan be done without removing any body panels. its the horizontal jog i find difficult to work on wether im going for the jug or the carb.. Its a biotch... I guess its just what you get used to.
Post by spaz12 on Oct 26, 2015 1:07:22 GMT -5
So, today I went and worked on it. Fixed a few little problems and then went to test ride it. Wouldn't hardly move. So I was hoping that my new air box hadn't come with a filter...it did. So I oiled up the filter really good, slapped it back in and she would go, but having a real hard time of it. It would do probably twenty or so at 3/4 throttle and die if I tried to give it any more. Well, I have zero MJ's for this little carb and I had time to kill so I set about trying to restrict the flow into the carb. Got close, but I know that whatever I do probably wouldn't last anyway and so I gave up for the night. Gotta order some jets I guess. I'll also bring my leak down tester with me tomorrow so that i'm not fighting a losing battle.
All in all, didn't get hardly anything done.
But, one of my buddies neighbors has an 06 Aprilia RSV 1000R (in perfect condition) that belongs to her 72 year old father and that she just wants out of her garage.... I won't say any more and jinks it.
Post by ams417 on Oct 26, 2015 8:59:09 GMT -5
I would love to have that. I used to ride my buddies TL1000R all the time. Something about a V Twin in a super bike just puts a smile on my face.
Post by aeroxbud on Oct 26, 2015 18:11:50 GMT -5
I always thought working on my vertical jog was easy compared to the horizontal jog. On the vert jog i just pulled bidy panels to accss the jug and carb workcan be done without removing any body panels. its the horizontal jog i find difficult to work on wether im going for the jug or the carb.. Its a biotch... I guess its just what you get used to. On the Aerox horizontal you have to remove the seat and side panels to get easy access to the carb The RSV is a true Italian superbike Spaz. Not the easiest thing to ride but very exciting
Post by existorlive on Oct 26, 2015 18:20:03 GMT -5
Hey Spaz, got my prebug on the street tonight. Must say its fun as hell. the front end just doesnt like to stay on the ground and it could definetly use better brakes. You dont happen to know if the front end off a horizontal zuma will swap over?
Post by niz76 on Oct 26, 2015 18:38:04 GMT -5
I use a small bag that I zip tied to rear rack for a little storage. It will hold a bottle of oil and a couple tools etc etc. Here's a bad pic, but I'm sure you get the idea. I had not thought of that! Now I just have to go buy one of those damn expensive racks. Do you use the stock air box? That thing was a huge PITA to get on! I had to have help lol Literally the only reason I ran open filters on both prebugs was so I didn't have to deal with that danged stock airbox on and off while carb tuning. What a funkled conundrum design that is! Love how simple it is to get to the carb with a pod filter on it!
Post by spaz12 on Oct 26, 2015 20:36:46 GMT -5
I always thought working on my vertical jog was easy compared to the horizontal jog. On the vert jog i just pulled bidy panels to accss the jug and carb workcan be done without removing any body panels. its the horizontal jog i find difficult to work on wether im going for the jug or the carb.. Its a biotch... I guess its just what you get used to. On the Aerox horizontal you have to remove the seat and side panels to get easy access to the carb The RSV is a true Italian superbike Spaz. Not the easiest thing to ride but very exciting I've been reading all about it the RSV. I want it pretty bad.
Post by spaz12 on Oct 26, 2015 20:39:27 GMT -5
Hey Spaz, got my prebug on the street tonight. Must say its fun as hell. the front end just doesnt like to stay on the ground and it could definetly use better brakes. You dont happen to know if the front end off a horizontal zuma will swap over? I think so probably because I've saw plenty of them with Aerox wheels and forks. Look up MBK Booster (same scoot) and you'll see what I'm talking about.
Post by spaz12 on Oct 26, 2015 20:42:32 GMT -5
I had not thought of that! Now I just have to go buy one of those damn expensive racks. Do you use the stock air box? That thing was a huge PITA to get on! I had to have help lol Literally the only reason I ran open filters on both prebugs was so I didn't have to deal with that danged stock airbox on and off while carb tuning. What a funkled conundrum design that is! Love how simple it is to get to the carb with a pod filter on it! I'm actually dreading tuning this carb. I was really, really hoping that I could get the tuning down by restricting the airflow because I can see how difficult swapping jets out is going to be. If I had the money, I'd get a Dellorto racing carb for it.
