Post by spaz12 on Apr 24, 2016 19:41:59 GMT -5
A plastic spacer in the variator is another restriction on that scoot.
Post by ThomasTPFL on Apr 24, 2016 23:04:34 GMT -5
Anyone who is familiar with these, know what's interchangeable with the front brake? A friend of mine has one and his front brake seals are going. He has not been able to track down the brake parts. Rather worrisome as its a 60+ mph bike. Easyparts.nl and oemmotorparts.com are good places for Derbi parts. If you you/he can't find parts then I have a caliper. Thanks! I passed the info on.
Post by stepthrutuner on Apr 25, 2016 1:13:44 GMT -5
The brass holey restrictor and spacer referred to are the only restrictors. Around 48 mph is typical for stock top speed for a middle weight rider.
Post by oldgeek on Apr 25, 2016 16:24:58 GMT -5
It is amazing the hack job people are capable of. On a basically new scooter to boot.
Post by gsx600racer on Apr 25, 2016 17:13:10 GMT -5
Nice find Oldgeek. I resurrected one over the past winter. I ride with a couple guys here that have them too. One is unrestricted with a Leo ZX, does a solid 45-50 on the flats and has great takeoff. The other is bone stock with the restrictions and does a solid 40-45. They are nice machines, and well built. I had some issues finding some parts, 95% are sourced overseas.
Post by ThomasTPFL on Apr 25, 2016 18:23:55 GMT -5
My friend's has a Malossi 70cc topend, Malossi variator, some sort of performance clutch, and a pipe made for something else that they made fit. It keeps up with big scooters right up to 60 or so. Riding it is what sold me on twist n go scooters.
Post by oldgeek on Apr 27, 2016 13:36:41 GMT -5
I pulled the body plastics off to get a look at the carb and CVT. The carb restrictor was gone already, as was the plastic variator spacer. They also threw out the air filter in favor of a small piece of sponge, I guess in an attempt to tune the carb. It still has the stock 60 main jet, and the float bowl drain screw was silicone to hell and back with pieces of silicone floating in the bowl. LoL! The CVT bolts were all rounded off and tight as hell, I was surprised I was able to get some of them off. The CVT components are like new, and as others here have said they are basically already over range components.
I need to buy another bowl and drain screw for the 17.5 PHVA carb, or possibly just put a 19 PHBG on in its place. If I put the PHBG on I will loose the electric choke, so I would have to figure something out for that.
I rode the scooter a good bit, and it is a little on the small side for me, but I hate to think about selling this thing, as it is nice!
Post by oldgeek on Apr 27, 2016 13:39:39 GMT -5
Post by derbiman on Apr 27, 2016 19:44:22 GMT -5
Ebay Germany is a good place to find Derbi parts.
Post by stepthrutuner on Apr 27, 2016 20:00:00 GMT -5
If my memory serves me right 835 is the correct belt length and 28 degrees is the angle. The 805 belt is for the Derbi motor.
Post by gsx600racer on Apr 27, 2016 20:35:10 GMT -5
Here are some pictures of the CVT. Quite a bit of the rear pulley is unused, I may need a longer belt? Just make sure you get the belt for the 2t version. I made the mistake and got the belt for the 4T version and that belt size is the only thing it will fix. (Derbi Atlantis 4t) PS, in the last pic, I see that blue ZX in the background. lol
Post by gsx600racer on Apr 27, 2016 20:40:12 GMT -5
I pulled the body plastics off to get a look at the carb and CVT. The carb restrictor was gone already, as was the plastic variator spacer. They also threw out the air filter in favor of a small piece of sponge, I guess in an attempt to tune the carb. It still has the stock 60 main jet, and the float bowl drain screw was silicone to hell and back with pieces of silicone floating in the bowl. LoL! The CVT bolts were all rounded off and tight as hell, I was surprised I was able to get some of them off. The CVT components are like new, and as others here have said they are basically already over range components. I need to buy another bowl and drain screw for the 17.5 PHVA carb, or possibly just put a 19 PHBG on in its place. If I put the PHBG on I will loose the electric choke, so I would have to figure something out for that. I rode the scooter a good bit, and it is a little on the small side for me, but I hate to think about selling this thing, as it is nice! My friend has a 19mm, and it runs solid. I think its this and it retains the e-choke. www.racingplanetusa.com/carburetor-arreche-19mm-piaggio-derbi-p-7260-1.html?backcPathco=25&cPath=738_10294#.VyFsP_krKHs
Post by oldgeek on Apr 27, 2016 20:46:32 GMT -5
I pulled the body plastics off to get a look at the carb and CVT. The carb restrictor was gone already, as was the plastic variator spacer. They also threw out the air filter in favor of a small piece of sponge, I guess in an attempt to tune the carb. It still has the stock 60 main jet, and the float bowl drain screw was silicone to hell and back with pieces of silicone floating in the bowl. LoL! The CVT bolts were all rounded off and tight as hell, I was surprised I was able to get some of them off. The CVT components are like new, and as others here have said they are basically already over range components. I need to buy another bowl and drain screw for the 17.5 PHVA carb, or possibly just put a 19 PHBG on in its place. If I put the PHBG on I will loose the electric choke, so I would have to figure something out for that. I rode the scooter a good bit, and it is a little on the small side for me, but I hate to think about selling this thing, as it is nice! My friend has a 19mm, and it runs solid. I think its this and it retains the e-choke. www.racingplanetusa.com/carburetor-arreche-kymco-peugeot-p-838-1.html?backcPathco=25&cPath=2_622#.VyFphPkrKHsThat carb wont fit the derbi! That is for the Kymco. I got too many projects going as usual.
Post by gsx600racer on Apr 27, 2016 20:51:59 GMT -5
That carb wont fit the derbi! That is for the Kymco. I got too many projects going as usual. Sorry, pasted wrong link, its fixed now.
Post by oldgeek on Apr 27, 2016 21:14:47 GMT -5
That carb wont fit the derbi! That is for the Kymco. I got too many projects going as usual. Sorry, pasted wrong link, its fixed now. Ah... That one will fit. How are the Arreche carbs? I have only worked with the Dello PHBG's. Will the stock echoke fit on the Arreche?
