Post by thephranc on Jul 12, 2016 19:41:04 GMT -5
Got a little week day shop time in. Finished designing the part of the mount that will attach to the motor. Its 1/8 steel. CAD And this is as far as I got today. Spent too much time running to Lowes to get spray can glue
Post by thephranc on Jul 15, 2016 21:30:07 GMT -5
Its one thing to run out of argon because you were welding a tonne or metal, its another to run out because you're an idiot that left the valve open on a fresh tank......... Did find a place thats open on weekends though.
Post by thephranc on Jul 18, 2016 16:15:33 GMT -5
Motor side of the mount is done. Its way meatier than its needs to be. BUt its the only plate I had on hand.
Post by joeorange on Jul 18, 2016 18:52:30 GMT -5
Motor side of the mount is done. Its way meatier than its needs to be. BUt its the only plate I had on hand. better to be safe then sorry.
Post by tatteredmetal on Jul 18, 2016 20:50:53 GMT -5
What design software are you using? Flexi?
Post by thephranc on Jul 19, 2016 16:22:21 GMT -5
What design software are you using? Flexi? Yup. I'm a signman by trade.
Post by tatteredmetal on Jul 19, 2016 19:11:10 GMT -5
What design software are you using? Flexi? Yup. I'm a signman by trade. I figured. My father owned his own shop for years before retiring. It's nice to be able to give him a call and get some vinyl outputted
Post by thephranc on Jul 24, 2016 10:12:22 GMT -5
Got the tire mounted on the wheel and the wheel on the scooter. ..... Major setback. I now need the brake,shock,muffler swing arm mount bracket thing. Not easy to find and I don't want a cast alum one like a stock Majesty since it will most likely need to be modded. Might just make one.
Post by thephranc on Jul 24, 2016 17:30:33 GMT -5
There are a few inches of shaft sticking out past the wheel. Even with the rotor on it will still be a lot. This area is typically taken up by the shock, brake caliper, muffler mount. Got about 3/8 inch of clearance. You can also see the 2 mounting holes for the swing arm mounting bracket. After looking at factory parts I may scrap my motor mount and buy a stock one. Doing some math the I dont think load and pivot sits in a very good place if I keep going with what I got. I'll some weeks to think about it because I'm at a fiduciary wall for the next 2 weeks.
Post by Deleted on Jul 30, 2016 13:07:53 GMT -5
What an awesome project! I am looking forward to seeing the rest.
Good luck.
Bill
Post by thephranc on Aug 6, 2016 19:24:45 GMT -5
Had to turn the intake around. Turns out is an alum piece with a plastic coating. It could use some porting and polishing, as you can imagine quality isn't exactly top notch. That crossmember will be getting cut out and another added behind the intake. Final ride height and engine location determined. Thanks to a super accurate jig.
Post by arkie on Aug 10, 2016 3:18:05 GMT -5
Post by thephranc on Aug 21, 2016 10:01:32 GMT -5
The swingarm, mounting bracket finally showed up and its the wrong part. Not been able to do much because of the weather and now that it looks like there will be a break in the heat and humidity I don't have much to do. Hopefully I can get the part switched out for the correct one in a timely manner.
Post by fts902 on Aug 22, 2016 20:35:47 GMT -5
Nice. More pictures!
Post by thephranc on Aug 28, 2016 15:40:34 GMT -5
Finally got the mount lined up and tacked in today after many hours of checking and rechecking plum, level, straight and true. Hardly done though I am going to add 2 more braces that splay out and back from the mount to just in front of the gas tank hoop. Leaving just the up the uprights would not hold to lateral forces. The best part is I can now take the heavy front forks off and move things around on the table to get some more work going. Still need a swing arm though. I thought I found a local-ish place, that had one but I don't think they exist anymore. No one at the brick and mortar store, no store there either. No answering of the phone either. Left a message so hopefully some one will call back.http://www.scootersparts.net/index.php?main_page=product_info&cPath=1_972&products_id=2617 I'd like to make sure it will fit in person. They also show a punch of other little things I will need for this build.
