Post by arkie on Jun 6, 2017 17:50:45 GMT -5
Dude, seriously? From the rear that thing is sexy. I'd like it flipped right side up so its wider at the top but the way the plastic is in the back I cant get it to fit right. Maybe after you start on the fairings you can make it fit. +1 on the sexy.
Post by thephranc on Jun 9, 2017 20:03:24 GMT -5
Post by thephranc on Jun 10, 2017 18:04:10 GMT -5
Spent 6 hours on making a bracket that held my rear lights.
Post by thephranc on Jun 11, 2017 16:31:21 GMT -5
Super exciting fan brackets
Post by spaz12 on Jun 11, 2017 23:49:59 GMT -5
Are you using a brake to bend all that metal?
Post by thephranc on Jun 12, 2017 5:54:17 GMT -5
Are you using a brake to bend all that metal? A press brake to be exact. 20 tonne Harbour Freight press and the brake is from Swag Off Road.
Post by thephranc on Jun 13, 2017 17:54:01 GMT -5
This happened today.Humidity was about 70-75% Pulled the seat cover off and cut back a tonne of foam. Use to pitch you forward now it sits you back in a bucket. Can any one tell me what "null" means in the context of this?
Post by 90GTVert on Jun 13, 2017 18:24:48 GMT -5
Post by thephranc on Jun 15, 2017 19:18:00 GMT -5
Post by thephranc on Jun 16, 2017 20:21:14 GMT -5
Handle pars with extra bar for mounts. Its 1" stand off for a signs with end cap. Run all the way threw on stainless all thread. That I got 6' of for a $1 at lowes marked down from 19.90. Going to bend the bars back some to get the center line of the ends and stem more in line. Its a 3" drop from the stock bars. Also found out the front shocks are dead. When I sit on it it just drops in the front.I need to find the front struts that allow me to put the matching wheel to the rear and bigger breaks.
Post by thephranc on Jun 17, 2017 21:43:41 GMT -5
Post by thephranc on Jun 18, 2017 16:42:33 GMT -5
Post by joeorange on Jun 19, 2017 9:25:18 GMT -5
this is turning out to be one awesome build. cant wait to see and hear it running.
Post by aeroxbud on Jun 19, 2017 9:45:05 GMT -5
Love what you are doing. Great work
Post by thephranc on Jun 19, 2017 17:47:12 GMT -5
Thanks guys. Its a labour of love and spite. Redid the seat covering. Came out way better then version 1. Its very comfortable. Need to smooth out the shape some more before doing it all over again with the good foam. Got the bar bent by my boys at 301 Garage. Perfectly even and angled. Thats about all I could manage with the humidity no painting today.
