Cincikid
Post by Cincikid on Sept 23, 2016 7:59:17 GMT -5
Best $ ive spent. The added power makes a nite and day difference out there on the road.
Post by Deleted on Sept 23, 2016 23:15:49 GMT -5
46.3 was not on flat ground, 40-41 would be the flat run speed.
The particular hill I hit 46.3 is probably going to be my downfall. It's where I learned what my tires say when they're being pushed to their limits ")
On the other hand, I now have 2254 miles on the BBK and going strong.
Post by renagade281 on Sept 24, 2016 5:05:01 GMT -5
My fastest on a downhill is 49.8 and I felt like my motor was going to blow so I let up lol. My average flat ground run is 42-43 mph
Cincikid
Post by Cincikid on Sept 24, 2016 7:14:45 GMT -5
37-40 on flat ground. (stock carb & pipe) I get there a lot faster and hills are much better. @ 300mi so far.
Cincikid
Post by Cincikid on Sept 28, 2016 12:04:58 GMT -5
Update: Iv got the cvt dialed in good now. 40 @ cruse and 46 mph top.(GPS) Hills are a breeze. Dropping around 2-3 mph on decent sized ones. I believe I could get better performance with a decent carb and pipe. @ 450mi.
Post by humanshield on Sept 28, 2016 16:33:28 GMT -5
Update: Iv got the cvt dialed in good now. 40 @ cruse and 46 mph top.(GPS) Hills are a breeze. Dropping around 2-3 mph on decent sized ones. I believe I could get better performance with a decent carb and pipe. @ 450mi. Dood...that's the best I can get from my 50mm kit. Good job! What's your RPMs at 40 ?
Post by renagade281 on Sept 29, 2016 4:53:25 GMT -5
Update: Iv got the cvt dialed in good now. 40 @ cruse and 46 mph top.(GPS) Hills are a breeze. Dropping around 2-3 mph on decent sized ones. I believe I could get better performance with a decent carb and pipe. @ 450mi. what brand and weight rollers are u using
Cincikid
Post by Cincikid on Sept 29, 2016 10:38:51 GMT -5
"Dood...that's the best I can get from my 50mm kit.
Good job!
What's your RPMs at 40 ?"Thanks man. Wish I knew. I have the Trailtech on the scoot wish list. But not wound out at all. Nice comfortable, happy RPM range. Probably a little under peak powerband. "what brand and weight rollers are u using"Ok. Let's clarify a little, Then set up. Cruse for me is a smidge under WOT. Top was tucked on smooth, flat, blacktop W/ stands of trees on each side (no wind). Bike: 14 Dykon Express QMB 47mm BBK ($35). A9 cam, Stock head, pipe and carb - W/ pod filter. 10w 40. Cvt: Stock clutch W/ yellow torque and clutch springs. Hoca 169-415 Performance Variator 5 and 6g cheap SPExpress rollers. (I have weighed the rollers and each is off a little from the next. can't recommend) Bando 669 18 30. Belt seems a little short and wide compared to my stock belt. (doesn't run all the way to the top) 165Lb rider. Blue CDI, Orange ignition, Ngk spark. -Your CVT needs may differ, This works well for me.-
phatmanxxl
Post by phatmanxxl on Oct 10, 2016 14:23:11 GMT -5
Got about 500 miles in, still can't get past 32 MPH, ordered some 7 gram rollers to see if that will help.
Post by humanshield on Oct 10, 2016 15:21:56 GMT -5
Got about 500 miles in, still can't get past 32 MPH, ordered some 7 gram rollers to see if that will help. The big benefit of the 50mm kit is torque. The 50mm kit offers a significant torque increase over the 47mm kit which would help a lot with a heavier load. However, like others have pointed out, the 50mm kit is a bit less forgiving in high rpm conditions. On my scoot with the 50mm kit I find I don't have to wring it out as hard to move along good due to the extra torque. I don't push my scooter too hard. Rarely going over 7,500 rpm @ about 37 - 39 mph. If I go WOT, I can get to 46 and change fairly easily. Never went more than about 1/2 mile or so. I guess I might hit 47-48 on a long enough smooth flat, tucked. I weigh 210 now (but slowly getting heavier because I like beer) :-( Anyway, if you're not one to push your scoot too hard, a 50mm kit might really help you. Otherwise, if you tend to like WOT a lot, I would stay with the 47mm kit and keep twerking it like you're doing. Good luck.
larryhobman
Post by larryhobman on Oct 10, 2016 21:26:13 GMT -5
I had a chance to ride a stock motor today and I forgot how little power they have. With my current 47mm set up I run 45mph @8200 I have done a lot of testing with different springs and sliders of different weights. I do have the 49/17 gears and was wondering if they had actually helped me or made no difference in the end. The only failure I have had was the base gasket leaked, no leaks with the new one. The head I run was from a 60cc model and I was thinking of trying the 49cc head to see if I have more compression.
I currently run a 1500 main spring, gives nice torque but I was able to go faster on the top end with a 1000 main spring near 50mph
Any thoughts on this let me know
Post by Deleted on Oct 18, 2016 0:01:20 GMT -5
Rolled 3000 trouble free miles on my Glixal kit today, no problems with the carb either.
fergulious
Post by fergulious on Nov 2, 2016 23:13:22 GMT -5
My 50mm is back on my work bench for new configurations since ive installed the 47mm quality BBK and i love it. 1500rpm contra spring, performance variator and i got a better vented clutch bell. Awesome! the 50mm will be back on there soon few weeks but 47mm for now getting good torque and top end 50-52 on flat and most hills 40-43 significant hills 35-38. Everything takes just a little longer the the 50mm but didnt loose but 5-8 mph tho. im a 6'2" 175 pounds tho so that maybe be why. My goal is to build a 50mm kit thats as reliable as this 47mm bbk with top speeds in the high 60s. Also just to clarify ths is a hobby for me not a much needed use of transportation but i do ride it to work everyday 60 miles round trip i love the ride.. THX ill keep you posted
fergulious
Post by fergulious on Nov 8, 2016 14:05:45 GMT -5
WELL BLOWN THIS KIT TO IT WAS COMPLETELY MY FAULT I PUSHED IT TO SEE IF I COULD AND YES BROKE THE PUSH ROD AT THE CONNECTOR ON THE PISTON. bACK TO THE BOARD I WILL FIGURE OUT A BUILD THAT WILL RIDE WOT ALL THE TIME. JUST ORDERED MY OIL COOLER AND NEW TOP END KIT ILL BE USING A LONG CASE BLOCK THIS TIME
Post by humanshield on Nov 8, 2016 14:16:07 GMT -5
My 50mm is back on my work bench for new configurations since ive installed the 47mm quality BBK and i love it. 1500rpm contra spring, performance variator and i got a better vented clutch bell. Awesome! the 50mm will be back on there soon few weeks but 47mm for now getting good torque and top end 50-52 on flat and most hills 40-43 significant hills 35-38. Everything takes just a little longer the the 50mm but didnt loose but 5-8 mph tho. im a 6'2" 175 pounds tho so that maybe be why. My goal is to build a 50mm kit thats as reliable as this 47mm bbk with top speeds in the high 60s. Also just to clarify ths is a hobby for me not a much needed use of transportation but i do ride it to work everyday 60 miles round trip i love the ride.. THX ill keep you posted Fergulious..... If you want to go WOT a lot, have you considered a 2T scoot? They are much more forgiving and have great top ends with a few mods. Don't get me wrong, I love my 4T's but as far as scooters, you seem like a great candidate (based on your desires with your scooter hobby) for a 2 stroke scooter.
