Post by nelson on Sept 15, 2016 21:13:10 GMT -5
All those big 500cc single 2T's are built super mild as no humans could handle full roadrace specs,,vibes and traction are a big concern also,but hey,,didnt Maico build a 700cc single?? Or kz750? The tripple i believe be nice cafe racer
Post by nelson on Sept 15, 2016 21:45:48 GMT -5
nelsoneither your hand is big or that radiator is smaller then I thought. Which is great to build into a small Jog or Honda. Do you have specs? Dimensions? And why 10hp only, does that mean you need more radiators if you go above 10hp? Its not huge but i would say it will have no issue keeping a 70 cool. Its was made for a cr80(honda) dirtbike, I would say 12in tall x 5 wide x 2 inches deep. Its gonna fit into the front plastics somehow! Its a bit wide but i think it will fit between steering stem and edge of front plastics. You got it backwards, shiny radiators add hp and then you need more engine!
Post by tsimi on Sept 15, 2016 21:53:00 GMT -5
Post by birdman on Sept 15, 2016 22:42:32 GMT -5
+1
Post by spaz12 on Sept 15, 2016 22:48:43 GMT -5
Post by Lucass2T on Sept 16, 2016 3:26:25 GMT -5
All those big 500cc single 2T's are built super mild as no humans could handle full roadrace specs,,vibes and traction are a big concern also,but hey,,didnt Maico build a 700cc single?? Or kz750? The tripple i believe be nice cafe racer Zabel 700 sidecar engine. Or the MTH 650. My cr500 has an ex-sidecar engine in it. Ported big bore cylinder and lowered compression for a wider powerband.
Post by spaz12 on Sept 16, 2016 3:30:33 GMT -5
Or kz750? The tripple i believe be nice cafe racer Zabel 700 sidecar engine. Or the MTH 650. My cr500 has an ex-sidecar engine in it. Ported big bore cylinder and lowered compression for a wider powerband. What's with the weird front suspension?
Post by Lucass2T on Sept 16, 2016 3:46:22 GMT -5
Zabel 700 sidecar engine. Or the MTH 650. My cr500 has an ex-sidecar engine in it. Ported big bore cylinder and lowered compression for a wider powerband. What's with the weird front suspension? Dunno, thats just how MX sidecars look i guess. Maybe something with sideway forces on the front wheel during cornering?
Post by nelson on Sept 18, 2016 19:03:55 GMT -5
youtu.be/tI8mTIJ-va8Took a bit to figure water pump out. Remembered what ryan said all air had to be purged better to figure it out now than once its installed running off scoot battery
Post by nelson on Sept 18, 2016 19:11:04 GMT -5
Got brackets welded on and radiator mounted. Plastics were cut as well, dont want to show that pic just yet as its pretty crude. There is absolutely no room for a radiator but i got most of it hidden. Will show when done. And last but not least my wife sleeping on the garage floor, ahhh true love. A yoga mat and a fan and ahe slept for awhile!
Post by nelson on Sept 18, 2016 19:21:55 GMT -5
I a question im pretty sure i know the answer to. The pump and cylinder have 3/4 nipples that jave to be reduced down to 1/2 in. I bought some reducer fittings just wonder if this will be an issue with gph. Will it flow enough? The radiator has 1/2 nipples but is made for an 80cc dirtbike that gets ridden hard. Any input? Thanks in advance
Post by nelson on Sept 18, 2016 19:27:34 GMT -5
Ok, here it is at the moment. I just don't really like tje look of it, without mounting ot sideways on front of bike it wasnt going any place else. Amd it scares me as i had a heater core bust once and poured out on my toes, they had a recall bit i didn't get the memo..my toes were boiled. Hope this thing holds up!
Post by nelson on Sept 18, 2016 19:51:32 GMT -5
The c16 arrived..
Post by 190mech on Sept 18, 2016 19:56:41 GMT -5
Looks fine!Seen stuff in front of an enclosed fairing with no way for the air to flow through..Just cus it aint pretty,dont mean it aint fast!!(southern talk..)
Post by nelson on Sept 18, 2016 20:26:44 GMT -5
Looks fine!Seen stuff in front of an enclosed fairing with no way for the air to flow through..Just cus it aint pretty,dont mean it aint fast!!(southern talk..) Yea, i would prefer to ride a turd rocket than a lambo with a moped engine. Some like show, i like go. Cant afford both!
