Post by nelson on Sept 25, 2016 18:11:54 GMT -5
I tapped into a wire that came on with the key to run the electric pump. Could that be a problem?
Post by ryan_ott on Sept 25, 2016 18:15:07 GMT -5
If you have spark I wouldn't think so. Maybe carb or airleak. Too much oil in the motor from assembly could cause hard starting.
Post by nelson on Sept 25, 2016 19:07:01 GMT -5
If you have spark I wouldn't think so. Maybe carb or airleak. Too much oil in the motor from assembly could cause hard starting. I didnt use a lot of oil. Just a squirt in the bearings and a wet finger around the cylinder. Im going to assume an air leak. That doppler intake is SHIT.Since im using a 19mm(might be a 21)might just go with stock intake. What about reeds? I used the stock block with the cf reeds that came with cylinder. I assembled correctly just never know, i prefer to just buy a set of v3. But not an option atm. If it is the carb off it should still fire off?
Post by 190mech on Sept 25, 2016 19:17:52 GMT -5
Is the plug wet?If not add a bit of premix in the plug hole and see if it fires..
Post by ryan_ott on Sept 25, 2016 19:38:02 GMT -5
Post by nelson on Sept 25, 2016 19:49:53 GMT -5
Is the plug wet?If not add a bit of premix in the plug hole and see if it fires.. Plug is wet but i guess could still be fuel starved. Maybe an issue with the carb. Will take some poking and prodding will report back when im allotted some more man time!
Post by spaz12 on Sept 25, 2016 20:00:41 GMT -5
I have no doubts that you'll get it running. I'm sure that it's something simple. EDIT: I specifically looked up to see if there was another page and there wasn't one. Pressed the button and here's another damn page.
Post by oldgeek on Sept 25, 2016 20:20:39 GMT -5
What about reeds? I used the stock block with the cf reeds that came with cylinder......... I dont think your reeds are the issue, but I have a theory about using CF reeds with a stock style cage. The CF reeds can shatter slapping the stock hard plastic cage. I feel the CF reeds are better suited for the viton coated cages. [/quote]
Post by nelson on Sept 26, 2016 20:06:07 GMT -5
Post by spaz12 on Sept 26, 2016 20:10:16 GMT -5
It sounds angry
Post by Jwhood on Sept 26, 2016 20:34:13 GMT -5
Nice kickstand!!!
Post by nelson on Sept 26, 2016 20:49:22 GMT -5
It sounds angry Oh its pissed!
Post by nelson on Sept 26, 2016 20:51:15 GMT -5
Nice kickstand!!! I will likely modify the stock stand, or just wear the bucket on my head and when i stop use it for a kickstand
Post by Jwhood on Sept 26, 2016 20:53:57 GMT -5
Sounds good bro!!
Post by spaz12 on Sept 26, 2016 21:01:24 GMT -5
So what was it that was stopping it from running?
