Post by thxcuz on Sept 12, 2016 11:00:00 GMT -5
I JUST finished buttoning up the scooter for hopefully the last time for a while. I was riding it jauntily through the neighborhood and heard a pop or a thud or some sound that sounded like a sound I wouldn't like to hear. The sound of sudden sadness. I thought maybe I broke a belt... nope it was fine. I'm afraid I'll have to take it apart again and I'm almost positive I won't like what I see. When I try to start it I hear things moving but not the usual thump thump of a piston moving. I won't know until I take it apart YET AGAIN! My fear is that my crank broke. That $100 Spare parts scooter doesn't seem like such a bad idea now.
Anyone want to buy a broken tao tao? Who am i kidding... nobody does.
I got my bicycle out and rode that. My good old Schwinn never let me down.
Sorry. Had to vent
Post by acvw74 on Sept 12, 2016 11:43:56 GMT -5
Sorry to hear this! You can check the crank without taking it apart...look to see if the fan is turning while you try to start. It doesn't rule out a broken rod...but a place to start.
I wish you luck!
Post by humanshield on Sept 12, 2016 12:13:53 GMT -5
Look at it this way....every time you take it apart you will get better and better at it.
Kinda odd you would break a crank. Lots of people with BBK's ride them hard and don't break cranks. Could be something in the valve train. I wonder if you got the piston pin clips in properly?
Then again, sometimes it's cheaper to pay someone with experience to do it after all is said and done.
Post by tortoise2 on Sept 12, 2016 12:42:44 GMT -5
Have to wonder . . if you would have saved yourself a LOT of aggravation by initially selecting a 150cc TaoTao, made NO modifications, and just performed routine maintenance? The Yamaha Zuma 125's have completed several cross-country rides with very few issues.
Post by 90GTVert on Sept 12, 2016 12:47:44 GMT -5
Hopefully it won't be nearly as bad as you're expecting. Go over the basics (fuel, air, spark, compression) before you take too much apart.
Post by thxcuz on Sept 12, 2016 13:15:45 GMT -5
I checked the valves, they are ok. Could very well be a circlip. I find those the be the hardest thing to work with. I ran my old Puch Maxi with one clip for a short time because I had so much trouble getting it in. I put it back in not long after.
I miss that puch. I should have kept it
Post by thxcuz on Sept 12, 2016 13:22:01 GMT -5
Have to wonder . . if you would have saved yourself a LOT of aggravation by initially selecting a 150cc TaoTao, made NO modifications, and just performed routine maintenance? The Yamaha Zuma 125's have completed several cross-country rides with very few issues. I have no doubt that I would. I came across this whole scooter thing by accident. I had a moped. Then got into those 66cc engines you bolt on a bicycle. It ran great but it was kinda dangerous. I put an ad on cl looking to trade it for another moped. This guy had 2 scooters a Tao tao that "just needed a new cdi" Or a kymco that "just needed a piston" I chose the tao because I thought it would be easier. If I were to do it over again I would have gone with 150 in a heartbeat. Or just get another Puch
Post by thxcuz on Sept 12, 2016 13:59:18 GMT -5
Fan spins, valves are set properly but my finger test gives me no compression
No compression = much depression
Post by humanshield on Sept 12, 2016 16:51:35 GMT -5
Piston wrist pin clip came out...chewed up the rings and piston WAG
Post by Deleted on Sept 12, 2016 17:16:45 GMT -5
Drain the oil, look for anything that should not be in there...metal pieces and chunks would be an example. Cost you a quart of oil, and 5 minutes, to find out if something really bad happened in there.
I hope it is not bad.
Bill
Post by thxcuz on Sept 12, 2016 17:46:47 GMT -5
Piston wrist pin clip came out...chewed up the rings and piston WAG I'm almost positive that's what happened. But I've been wrong before. Fortunately I have a spare piston and cylinder. I'd also like to remove the engine this time just so I know how to do it. Plus these engines are a bit of a knuckle buster. I guess I'm not chucking it in the river after all
Post by humanshield on Sept 12, 2016 17:56:49 GMT -5
It's worth the trouble. When you finally get them running just right....it's awesome fun
Post by ThomasTPFL on Sept 12, 2016 19:24:34 GMT -5
Have to wonder . . if you would have saved yourself a LOT of aggravation by initially selecting a 150cc TaoTao, made NO modifications, and just performed routine maintenance? The Yamaha Zuma 125's have completed several cross-country rides with very few issues. Ahhh.... But having a 50mph 50cc is special, takes work and knowledge. Or money to buy an SR50.
Post by thxcuz on Sept 12, 2016 20:53:55 GMT -5
Have to wonder . . if you would have saved yourself a LOT of aggravation by initially selecting a 150cc TaoTao, made NO modifications, and just performed routine maintenance? The Yamaha Zuma 125's have completed several cross-country rides with very few issues. Ahhh.... But having a 50mph 50cc is special, takes work and knowledge. Or money to buy an SR50. 50mph on a 50cc 4 stroke? What kind of sorcery are you speaking of, kind sir? One should not dabble in the dark arts
Post by jstich on Sept 12, 2016 21:37:38 GMT -5
50 mph on a 49cc 4T not that strange. I've hit 50 indicated on mine a few times with only an iridium plug and needle adjustment.
