Post by humanshield on Oct 2, 2016 17:27:17 GMT -5
Floyd, It's common for them to fail. And, they can work one minute then not the next. Chances are it's the Bendix. It's ok if it's a bit loose like that.
Also always remember..... For every ONE MINUTE you use your starter....let it COOL for 15 minutes. (Otherwise it can get damaged)
Post by floyd2133 on Oct 2, 2016 18:26:59 GMT -5
Ok I bought a new bendix coming Tuesday . however the problem looked as if the starter and bendix gear wasn't meeting up . In turn when it finnaly did after shaking and tapping cvt cover. It came out grinding. However I do need a new batt but that will be here tomorrow. I'm growing exhausted if my taotao of six months. It runs great but minor problems every 2 weeks
Post by floyd2133 on Oct 2, 2016 18:45:03 GMT -5
Thank you for your response buddy. However I'm open to all suggestions to fuel my gy6 brain
Post by floyd2133 on Oct 3, 2016 1:28:21 GMT -5
I believe I have a bad bushing . I ordered a starter bendix and bushing but not sure how to take old bushing out. Help please ? Old bushing is worn won't hold bendix center it Leans
Post by Cincikid on Oct 3, 2016 8:14:33 GMT -5
Pry or maybe a screw.
Post by Deleted on Oct 3, 2016 10:00:58 GMT -5
Use right sized screw inside bushing to get it tight. Some heat and pliers will do the rest.
Post by floyd2133 on Oct 3, 2016 10:30:03 GMT -5
Ok understood. However being that bushing is messed up could this be the cause of it not working properly?
Post by tortoise2 on Oct 3, 2016 10:33:04 GMT -5
One removal strategy is using a 3/8 inch tap . . then use a nut-bolt to tap in replacement bushing.
Post by floyd2133 on Oct 3, 2016 15:37:13 GMT -5
I have a picture of the starter and bendix gears they aren't toUching. Any quick fix until I can get the bushing vimeo.com/185382055
Post by acvw74 on Oct 3, 2016 15:50:43 GMT -5
I'm not sure if it is the bushing... a lot of filings around the starter gears are your starter teeth are worn down?
Post by floyd2133 on Oct 3, 2016 15:53:01 GMT -5
Yes it looks that way do I have to buy. New starter to fix that?
Post by gsx600racer on Oct 3, 2016 16:23:28 GMT -5
First, in you previous video's when you were trying to show us that the battery was bad, you were trying to start the scooter with the cvt cover off. BIG MISTAKE. I warned you you were going to ruin the starter bendix as well as the starter gear. Now the bushing is destroyed too. YOU CAN NOT RUN THE STARTER WITHOUT THE CVT COVER INSTALLED. Parts will get destroyed. You should replace the starter, bendix and the bushing. If not, you will be back here with the same problem. In the future, don't use the starter when the cover is off. Like in this vid. www.youtube.com/watch?v=mZrzqWtcWRQI would suggest having someone with the right tools that knows what they are doing to replace the bushing for you.
Post by floyd2133 on Oct 3, 2016 21:01:34 GMT -5
Ok old wise ones on 49cc I bought bendix starter and bendix 40 in all on ebay
Post by floyd2133 on Oct 3, 2016 21:02:19 GMT -5
Is there a vid or how to diagram on my upcoming project to show me how to do it until parts come in on Friday?
Post by gsx600racer on Oct 3, 2016 21:10:21 GMT -5
