Post by gsx600racer on Oct 3, 2016 21:24:26 GMT -5
Is there a vid or how to diagram on my upcoming project to show me how to do it until parts come in on Friday? Yeah, go back an read the first page of your post here, tortoise2 posted the steps with pictures on how to swap out the bushing.
Post by floyd2133 on Oct 4, 2016 9:43:34 GMT -5
What size nut and bolt do I need to tap in
Post by gsx600racer on Oct 4, 2016 12:10:12 GMT -5
Post by floyd2133 on Oct 4, 2016 14:55:03 GMT -5
Post by Deleted on Oct 4, 2016 15:17:44 GMT -5
What size nut and bolt do I need to tap in He said in his post: 3/8"-24 tap and the bolt and nut would be of the same size/pitch. Bill P.S. That means, 3/8" diameter and 24 threads/inch.
Post by floyd2133 on Oct 4, 2016 15:20:40 GMT -5
Ok I bought the tap
Post by floyd2133 on Oct 4, 2016 15:21:21 GMT -5
Post by floyd2133 on Oct 4, 2016 15:21:37 GMT -5
Ima get the nut too
Post by gsx600racer on Oct 4, 2016 15:29:34 GMT -5
I think the nut and bolt were smaller 1/4-20. To go inside the bushing to drive it in.(if you go back ans look at the pictures.
Post by Deleted on Oct 4, 2016 15:49:26 GMT -5
I think the nut and bolt were smaller 1/4-20. To go inside the bushing to drive it in.(if you go back ans look at the pictures. He (Tortoise2) said it was 3/8-24 and that is what the photo showed I believe. Bill
Post by Deleted on Oct 4, 2016 15:51:37 GMT -5
You bought 3/8-16 instead of 24 so you will have less threads to be pulling against when you remove it so, be careful. Bill
Post by floyd2133 on Oct 4, 2016 15:54:14 GMT -5
Be carful not to do what
Post by Deleted on Oct 4, 2016 16:01:36 GMT -5
With less threads per inch, you may only end up pulling against 2 or 3 threads so, if you are not careful, you will strip those few threads out when you run the nut on it as a puller. The higher threads per inch would have given you more threads to pull against as that bushing is not very long...maybe .500" or around there. That tap you bought is tapered and there will be no threads for the first .400" or so. Does this make sense to you? Remember, you are drilling and tapping into a blind hole. (Hole with a bottom) So, the end of the tap with no threads can not pass on through so...you only get a few threads. Bill
Post by gsx600racer on Oct 4, 2016 16:06:30 GMT -5
Post by floyd2133 on Oct 4, 2016 16:25:13 GMT -5
Okay I understand I'm gy6 ignorant and doing a lot of stuff for the first time witch is why I'm in this situation now smh
