Post by humanshield on Sept 17, 2016 9:51:31 GMT -5
Either a bad battery or you have a short that's draining the battery.
If you have a VOM, disconnect the negative battery lead, set the VOM to 10 AMP range, then connect one lead to the battery terminal and the other to the negative lead.
That will tell you if you have a current drain.
I suspect you just have a bad battery.
Post by floyd2133 on Sept 17, 2016 10:39:13 GMT -5
I have a multimeter however it was just working yesterday . I left it in trickle charge last night tried to start this morning and nothing happen
Post by floyd2133 on Sept 17, 2016 11:39:33 GMT -5
Starter solenoid test it just made a spinning noise when I touched it with the screw driver
Post by floyd2133 on Sept 17, 2016 11:47:03 GMT -5
Post by humanshield on Sept 17, 2016 12:02:56 GMT -5
Oh..then you probably just need a new solenoid. Easy easy to replace and only about $15 - $20
I didn't (and won't) click your link because it looks like it's supposed to be YouTube....but isn't
Post by floyd2133 on Sept 17, 2016 13:03:30 GMT -5
The link right above your post shows the YouTube video five
Post by gsx600racer on Sept 17, 2016 17:29:28 GMT -5
You dont have an ignition issue, you have a starter/battery issue. Get yourself a new battery and starter motor. At least a new battery. If you are charging it and its not holding the charge that should be a hint the battery is shot. I watched this vid of yours, www.youtube.com/watch?v=mZrzqWtcWRQWith all that grinding on the starter and bendix, the teeth on the starter are probably trashed or close to it. From the looks of your newer vid, someone replaced the variator fan and you now have the right belt installed.
Post by stoneforth on Sept 17, 2016 18:40:50 GMT -5
Starter solenoid test it just made a spinning noise when I touched it with the screw driver This has to be your 5th thread right? be better if you stuck to the same thread. Take your multimeter and measure battery voltage, then measure the voltage at the starter solenoid 12v connector. If they're the same when you press the switch you can rule out everything before the solenoid and starter other than grounding. If it spins without engaging when you bridge the solenoid it probably isn't getting enough power to engage. That'd be a battery issue or grounding issue. To rule out the battery i'd take it out of the bike and charge it overnight, then connect directly to the starter with jumper cables and see if it cranks. If it's still strong after a day without being connected to the scoot you probably have a short that's draining the battery.
Post by stoneforth on Sept 19, 2016 16:35:08 GMT -5
inb4 all advice is ignored and new thread is posted.
Post by floyd2133 on Sept 25, 2016 13:15:14 GMT -5
It is the battery
Post by gsx600racer on Sept 25, 2016 14:22:30 GMT -5
Well that seems to have been the general consensus here for the past month or so. My opinion, id get the kick starter fixed and start it that way till next spring. If you buy a battery now, we are heading into the winter months and how much riding do you plan to do ? Most small batteries only come with a 6 month warranty. Buy it now and if you don't ride it and keep the battery maintained(charged) over the winter months and it will be dead in spring and the warranty is gone. If you buy the battery next spring you will have all summer of riding and if you have a issue with the battery, you will have the warranty to fall back on. Just my
Post by floyd2133 on Sept 25, 2016 15:59:49 GMT -5
I bought the battery tender trick charger so I was going to buy the battery as well
a64.tinypic.com/bfbp.jpg
Post by floyd2133 on Oct 2, 2016 15:11:10 GMT -5
Post by floyd2133 on Oct 2, 2016 16:28:38 GMT -5
Any suggestions it worked this morning but now just spins
Post by floyd2133 on Oct 2, 2016 16:53:14 GMT -5
Here is better video I'm trying to figure out do I need a bendix or starter. Also the bushing in this video on the belt side were the bendix tip goes is warped I can see it in video. 'My bendix doesn't sit up right and I have a hard time getting cvt on youtu.be/yyJNMIDIrHc
