Post by Jwhood on Jan 24, 2017 22:49:51 GMT -5
Been doing research and talk to a guy from taida and they have a v8 style pipe there is a normal v8 and then a v8 gp,also they have an all chrome they are both for a bws 100,guy sent me a pic of the pipes but there only 1/2 pics
Post by Jwhood on Jan 24, 2017 22:50:12 GMT -5
Post by 190mech on Jan 25, 2017 4:49:33 GMT -5
It'd be nice to see the front end of the pipes to make sure it has the same tapered section as the original V8..
Post by Jwhood on Jan 25, 2017 7:10:34 GMT -5
It'd be nice to see the front end of the pipes to make sure it has the same tapered section as the original V8.. I asked the guy but still no response yet they also have a 54mm cylinder l.c for a jog 90
Post by 190mech on Jan 25, 2017 7:52:00 GMT -5
Ya got any links for those products??Dont forget you'll need a waterpump,hoses and rad for the LC...
Post by Jwhood on Jan 25, 2017 11:57:06 GMT -5
Ya got any links for those products??Dont forget you'll need a waterpump,hoses and rad for the LC... Dealing with a seller for there stuff I think he is in n.c,I'll post links soon as I get them
Post by Jwhood on Jan 25, 2017 13:40:28 GMT -5
Here is the chrome taida jog 90 exhaust
Post by Jwhood on Jan 25, 2017 13:42:28 GMT -5
It's 23.2 inch's and the exhaust can is 12 inchs
Post by Jwhood on Jan 25, 2017 13:45:44 GMT -5
Post by oldgeek on Jan 25, 2017 20:46:01 GMT -5
So will this crank work on +90cc cylinders? I guess a spacer will be needed to accommodate the 85mm con rod.
Post by joshua864 on Jan 25, 2017 22:24:05 GMT -5
David bullock the guy who runs gy6performance.com is who I get all my taida stuff from. He has stuff specially made for him. He could probably get you anything taida you want.
Post by Jwhood on Jan 25, 2017 22:29:24 GMT -5
So will this crank work on +90cc cylinders? I guess a spacer will be needed to accommodate the 85mm con rod. Yeah that's the guy I've been in touch with,j is he legit? David bullock the guy who runs gy6performance.com is who I get all my taida stuff from. He has stuff specially made for him. He could probably get you anything taida you want.
Post by niz76 on Jan 25, 2017 22:46:00 GMT -5
Post by 190mech on Jan 26, 2017 5:06:01 GMT -5
I didnt see the pipe or cyl kit in their listing,well known company though...
Post by 190mech on Jan 26, 2017 5:09:00 GMT -5
So will this crank work on +90cc cylinders? I guess a spacer will be needed to accommodate the 85mm con rod. All 90 cranks have an 83 or 85mm length rod on stock cranks...
