Post by gsx600racer on Nov 19, 2017 22:23:28 GMT -5
Thanks, that is what I thinking the answer would be. I actually spent some time searching for the answer myself and 7 vs 8 never came up anywhere I looked. There was LOADS of information at SKF's pages, but no answer to my question that I could find. The PDS is likely the hardest working bearing in a scoot. It might be wise to pay attention when selecting a bearing for it. It figures because I have 5 brand new bearings with 7 balls and only the 1 with 8. The difference from 7 to 8 is probably minimal if any. I just make sure I use name brand.
Post by oldgeek on Nov 20, 2017 21:47:14 GMT -5
Today I made the exhaust port changes and got the ex duration up to 193 with transfers now looking to be closer to 133 than 134. I tried to slightly flatten the ex port roof a bit, but I don't know if it came out right. I worked on this port extensively before so i have no idea how this port originally looked. Before today After today I wonder how the C16 pipe will work with this setup? Only one way to find out.
Post by vlatx on Nov 22, 2017 12:43:32 GMT -5
C16 wants to rev high so i think it will be ok
Post by oldgeek on Nov 22, 2017 23:40:20 GMT -5
I have been trying to get the gearbox squared away but it is giving me some trouble. Everything is loose until I tighten the gearbox bolts up. The intermediate gear is binding up. If I remove the little washer that goes between it and the large case half everything is perfect. I do not currently have a gasket between the gearbox case halfs, I think if I just use a gasket or 2 it will space it out just right....... 10.1:1 gears by the way.
Where to find some longcase gearbox gaskets quickly?
Post by Jwhood on Nov 23, 2017 0:17:12 GMT -5
I have been trying to get the gearbox squared away but it is giving me some trouble. Everything is loose until I tighten the gearbox bolts up. The intermediate gear is binding up. If I remove the little washer that goes between it and the large case half everything is perfect. I do not a gasket between the gearbox case halfs, I think if I just use a gasket or 2 it will space it out just right....... 10.1:1 gears by the way. Where to find some longcase gearbox gaskets quickly? Go get some gasket making material from local auto parts store and cut your own!!
Post by benji on Nov 23, 2017 0:19:54 GMT -5
I have been trying to get the gearbox squared away but it is giving me some trouble. Everything is loose until I tighten the gearbox bolts up. The intermediate gear is binding up. If I remove the little washer that goes between it and the large case half everything is perfect. I do not a gasket between the gearbox case halfs, I think if I just use a gasket or 2 it will space it out just right....... 10.1:1 gears by the way. Where to find some longcase gearbox gaskets quickly? Go get some gasket making material from local auto parts store and cut your own!! this is what I do on everything haha.
Post by oldgeek on Nov 23, 2017 0:37:13 GMT -5
I have been trying to get the gearbox squared away but it is giving me some trouble. Everything is loose until I tighten the gearbox bolts up. The intermediate gear is binding up. If I remove the little washer that goes between it and the large case half everything is perfect. I do not a gasket between the gearbox case halfs, I think if I just use a gasket or 2 it will space it out just right....... 10.1:1 gears by the way. Where to find some longcase gearbox gaskets quickly? Go get some gasket making material from local auto parts store and cut your own!! Too much work! I am lazy. Also there are some passages that are covered and I dont know which ones are and which ones are not. I will trace one so I can do that next time.... Come to think of it, I should have a pattern somewhere, or even a gasket in the shed now that I think of it. Scooter attack has them for .99, I will take 5 please.
Post by 190mech on Nov 23, 2017 5:14:19 GMT -5
Post by oldgeek on Nov 23, 2017 20:24:22 GMT -5
Do you think the Tecnigas RS II that you checked for us would be a better match than the C16? I could use the RS II instead.
Post by oldgeek on Nov 23, 2017 20:31:43 GMT -5
I found the gearbox gasket template I had in the shed along with a fresh gasket. I slapped the gasket on and sure enough, everything freed up and is smooth. All bearings in the gearbox are new with the exception of the secondary shafts main sealed bearing. I also have a new primary shaft in there, so the gearbox should not be a source of trouble unless I forget to put the gear oil in.
Post by 190mech on Nov 24, 2017 5:14:15 GMT -5
The RSII should be on the 'try list' also!
Post by Jwhood on Nov 24, 2017 19:31:48 GMT -5
Some one said the yasuni r might be a good fit can't remember who said it,I found a Leo Vince zx 100cc in the wild brand new only thing is the header needs to be cut and moved slightly cause it was meant for a magluti f12 not a biggie though
Post by oldgeek on Nov 25, 2017 19:58:21 GMT -5
I goth the crank installed. It went in really well. And surprisingly the crank seals went right into place with no problems for a change. I wish the cylinder and piston were ready to go but they are not. The cylinder needs a quick hone and then a thorough cleaning, and the new piston is untouched.
Post by drc174 on Nov 25, 2017 20:39:17 GMT -5
I am at a loss here, can you simply transform a Minarelli 50cc case into a 103cc?
Post by oldgeek on Nov 25, 2017 21:20:04 GMT -5
