Post by 90GTVert on Sept 20, 2024 9:14:36 GMT -5
I started the day off great. Decided to finally put the new brake pads on the TMAX that have been sitting here for a few months. Went to do the rear first and one bolt was barely over finger tight and the other was rounded. I think I saw the rounded one last time, but thought it wasn't that bad. I always torque to manufacturer spec.
I got the rounded one loose with vise grips. The problem is that it sits behind the e-brake and brake hose fitting. Removed the e-brake bolt so it would clear. The stock TMAX fitting had a curve to go up and allow the caliper bolt to be removed. Malossi's braided stainless kit has a straight fitting that's in the way. It's barely in the way though, so I figured I could squeeze it out of there. I was way wrong. I cracked the think junk aluminum fitting on the brake hose. I guess they're good for lightweight racing stuff, but I haven't liked how fragile the fittings seemed from day 1. I just found out the hard way how fragile they really are. Even cheap amazon hoses have steel fittings that you aren't going to come near breaking with minor pressure from something like this.
(The slight bend in the fitting was not me. That's their ineffective attempt to make clearance. The silver line right at the banjo is where it cracked.)
I think, well at least it's just a short hose. I'm gonna go with Yamaha. I don't want junk on this bike.
I look up Yamaha's hose on Partzilla. $170!!! They only sell the entire thing... hose at the lever, steel line in the middle and hose at the end. Can't get just the one part from Yamaha. Malossi kit is $200-ish and I don't want it anyway. I look at sites like Galfer and so on... TMAX not even listed. Well, I'm not giving Yamaha that kind of money for one piece of standard hose.
Looks like it's 20.5" overall. 10mm banjo on one end. 10mmx1.0 inverted flare on the other. I found these parts on Jegs. Much better price. I think the length will be close with fittings installed. I still need a new brake bolt though. Not sure if that will be more universal or I'll be waiting a week or so for Partzilla. EDIT : $30 for 2 bolts/pins from Partzilla. Sometimes you see parts listed for a hundred applications. These pins are only used on TMAX, Majesty and Morphous so they aren't common or in stock.
I know you shouldn't put any pressure on brake hoses. Not saying I'm not to blame. I do indeed wish to stay away from thin aluminum fittings from now on though. I was shocked when it cracked with what I'd call fairly light pressure. Did not expect it at all with what I was doing. The new hose will be straight too, but I'll bleed the brakes before I pay the money they want for full hose kits.
